Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2003, 05:48 PM   #1
SNISTER
CF Senior Member
Default Are C5 tire pressure sensors diameter insensitive?
In other words, if I put OEM 18's on the front of my car, can I reuse the sensor from the OEM 17 I take off?
SNISTER is offline   Reply With Quote
Old 02-25-2003, 12:22 AM   #2
Y2Kvert4me
CF Senior Member
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Support Corvetteforum!
Default Re: Are C5 tire pressure sensors diameter insensitive? (SNISTER)
Does not matter. Yes, you can reuse the sensors in your new wheels.
All it is, is a pressure gauge and a transmitter.
30psi in a 17" wheel is the same as 30psi in a 20" wheel.
:cheers:
[Modified by Y2Kvert4me, 4:23 AM 2/25/2003]
Y2Kvert4me is offline   Reply With Quote
Old 02-25-2003, 09:40 AM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
Default Re: Are C5 tire pressure sensors diameter insensitive? (Y2Kvert4me)
not all wheels can accept the sensors because of the way they mount .... some wheels have smaller valve holes or the valve hole is at the wrong angle (which does matter)
Luke@tirerack is offline   Reply With Quote
Old 02-25-2003, 11:21 AM   #4
SNISTER
CF Senior Member
Thanks -- it wasn't the pressure I was worried about, it was the mounting. I guess that wasn't completely clear from my original post.
Looks like I'll be fine.
Old 03-01-2003, 03:31 AM   #5
vrumvrum
CF Senior Member
vrumvrum's Avatar
I did it. The sensor is attached to the valve stem on newer models, They use the same on the backs and fronts.
vrumvrum is offline   Reply With Quote
Reload this Page Are C5 tire pressure sensors diameter insensitive?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
