Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-04-2003, 09:41 AM   #1
jerryp58
CF Senior Member
jerryp58's Avatar
Send a message via AIM to jerryp58
Default Wide Tire Effect on Suspension Components
Is there any detrimental effect to the suspension components caused by having wider than stock tires on my car?
I'm hoping the answer would be "No, as long as the car is aligned correctly".
I have a very stock '77 with the 8" rallye wheels. I currently have 245/60-15's on it (versus the 225/70-15 stock size) and I'm thinking of putting 255/60-15's since they're closer to the original diameter.
I'm currently dealing with worn side yokes (stub axles) and, even though this is a fairly common problem with these rears, I was wondering if the wider tires contribute to the problem (or any other suspension problems).
Thanks.
jerryp58 is offline   Reply With Quote
Old 01-04-2003, 04:02 PM   #2
tommelton
CF Senior Member
tommelton's Avatar
Default Re: Wide Tire Effect on Suspension Components (jerryp58)
Tire width alone should not cause extra wear. What accelerates wear on the suspension parts is incorrect offset. If you keep the same wheels, and just go to a different width tire (assuming ok for rim width), then there would be no extra suspension wear.
But, if you change wheels, and go from lets say, a zero offset wheel (equal front and backspacing) to a positive (?) offset wheel with higher frontspacing and shallower backspacing, then you will wear components out quicker, due to higher stress levels. But, it would be on the rear control arm bearings and the outer spindles, not the inner stub axles.
Tom Melton
82 CE
86 Z51 Coupe with 17x11.5" all the way around and bearing wear!
tommelton is offline   Reply With Quote
Old 01-05-2003, 11:55 AM   #3
jerryp58
CF Senior Member
jerryp58's Avatar
Default Re: Wide Tire Effect on Suspension Components (tommelton)
"Tire width alone should not cause extra wear" -- That's what I was hoping to hear :)
I'll be keeping my stock rallyes so my offset will not change.
Guess I'll start looking around for a 255 tire that has a reasonable section width so that I don't have to move e-brake cables or anything.
Thanks for the info,
Jerry
Old 01-06-2003, 09:01 PM   #4
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
255/60's were an optional tire size on the 78 and I don't believe that they did anything different to the bearings or suspension components just for the tire. You may have some clearance problems at the lower sides of the front wheel wells. There should be no clearance problems in the back.
When these tires were fitted to '78 cars on the assembly line in St. Louis, the workers had to clearance the lips of the fenderwells to keep the tire from rubbing on the fenders at full lock. Not a lot of material had to be removed, and not all cars had to have this done because of differences in the way the fenders were molded.
Just make sure to check when you have them mounted. Something like a Dremel tool should be all that is needed to provide any clearance.
If you are replacing the side yokes, it would be a good idea to do the bearings at the same time. Replace the control arm bushings and the link bolt bushings, too. Then if you replace the strut rod bushings, you pretty much have a complete rear suspension rebuild. Then have a good front and rear alignment done.
c4cruiser is offline   Reply With Quote
Old 01-07-2003, 02:14 PM   #5
SWCDuke
CF Senior Member
Default Re: Wide Tire Effect on Suspension Components (c4cruiser)
As long as wheel offset remains the same, suspension component loading won't change very much, depending on how much grip the tires have.
If you are looking for maximum grip you won't find it in a 255/60. The best currently available tires for Sharks are 225/70 or 235/70R- 15 V-rated police pursuit tires - GY Eagle RSA, General XP2000V, and Firestone PV41.
Duke
SWCDuke is offline   Reply With Quote
Old 01-07-2003, 06:32 PM   #6
Darkness
CF Senior Member
Darkness's Avatar
Default Re: Wide Tire Effect on Suspension Components (SWCDuke)
Actually 295/50-15 wont be a bad choice for grip either. There are several forum members that use them on the stock 8" rims (in the rear)
Later :cheers:
Darkness is offline   Reply With Quote
Reload this Page Wide Tire Effect on Suspension Components
Tags
15, 225, 70, police, pursuit, rated, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
How I can make the C6 fast as the C6 Z06 ? Oman_Supra C6 Tech/Performance 47 09-08-2005 06:49 PM
Brake Rotor Diameter? teabagger C6 Z06 Discussion 13 05-25-2005 07:28 PM
2005 Z06 Offical Gm Press Release NOVAVETTE C6 Corvette General Discussion 20 01-07-2005 10:38 AM
GM release (from another forum) Runge_Kutta C6 Z06 Discussion 11 01-05-2005 11:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
