Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-30-2002, 12:55 AM   #1
Trey395
CF Senior Member
Trey395's Avatar
Send a message via AIM to Trey395
Default Will these wheels fit? (specs included)
I have a set of Fittipaldi Tubolare's in 18x9.5 that were previously on my Camaro sitting in storage. I'm wondering if they would fit on the C5?
Here are the specs...
Front - 265/30/18's
Rear - 285/30/18's.
Offset is 7.25" Bolt pattern appears to be about 5x4.6ish
Almost forgot... if they do fit, will I have any troubles with ABS, TC, or the Speedo and what is the max. tire size I can run in the rear?
**EDITED** racewheel pointed out an error, specs corrected...
[Modified by Trey395, 9:25 AM 12/30/2002]
Trey395 is offline   Reply With Quote
Old 12-30-2002, 11:20 AM   #2
racewheel
CF Senior Member
Default Re: Will these wheels fit? (Trey395)
is the 10.5" measurment from outside edge to outside edge, if so they are 9.5" wide wheels. and if that is the case then at 7.25" backspacing they will fit reasonably well on a c5 although the front will be fairly close to the outside edge of the fender.
racewheel is offline   Reply With Quote
Old 12-30-2002, 11:24 AM   #3
Trey395
CF Senior Member
Trey395's Avatar
Default Re: Will these wheels fit? (racewheel)
I did measure from outside-inside rim. Thanks for the clarification...
Is the 285 the widest tire I can go with on the back with the 9.5?
Old 12-30-2002, 10:20 PM   #4
RCswish
CF Senior Member
RCswish's Avatar
Send a message via AIM to RCswish
The 295 will fit on the 9.5, but you would be better off staying with the 285 as you wont have as much tire wall flex. :yesnod:
RCswish is offline   Reply With Quote
Reload this Page Will these wheels fit? (specs included)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
