Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-22-2002, 03:30 AM   #1
BadMonkey
CF Senior Member
Send a message via AIM to BadMonkey
Default mini tub? how big without it?
Question, what is the biggest size you can fit under the rear without haveing to get the mini tub? And is there anyone who makes a 315 size in 18" wheels or will I have to run 17" all around. And on that note is there anyone running 17" all around on a C5?
BadMonkey is offline   Reply With Quote
Old 12-23-2002, 12:33 AM   #2
Dave00C5
CF Senior Member
Dave00C5's Avatar
Default Re: mini tub? how big without it? (BadMonkey)
From what I hear its a 11.5 wheel without tubbing. You can run a 315/35/18 on it . :cheers:
Dave00C5 is offline   Reply With Quote
Old 12-23-2002, 02:42 PM   #3
MARK'S_C5TT
CF Senior Member
MARK'S_C5TT's Avatar
Send a message via AIM to MARK'S_C5TT
Default Re: mini tub? how big without it? (Dave00C5)
You could supposedly run a 325 if you could find one!
I believe there are a few manufacturers that have 315/18's
street tires (Pirelli, Michellin, a few others).
BFG is coming out with an 18" DR in the spring - Nitto also.
MARK'S_C5TT is offline   Reply With Quote
Old 01-05-2003, 01:20 AM   #4
vrumvrum
CF Senior Member
vrumvrum's Avatar
These are 295-18's. I cannot slip my finger between the inner fender and sidewall. If you held up a yardstick against the sidewalls, it lines up with the outside of the fender perfectly. These are 10.5 rims.
Measure the outside of the fender to the inner fender you will get 12.5 " .
25.4 mm per inch 12.5 X 25.4 = 317.5 mm. You will have problems with the diameter though. You have to keep that in mind also.
[Modified by vrumvrum, 5:22 AM 1/5/2003]
vrumvrum is offline   Reply With Quote
Old 01-07-2003, 07:30 PM   #5
M396 #00-011
CF Senior Member
M396 #00-011's Avatar
11.5" rim w/ a 335/30/18. The backspacing has to be correct to work though.
M396 #00-011 is offline   Reply With Quote
Old 01-07-2003, 11:14 PM   #6
vrumvrum
CF Senior Member
vrumvrum's Avatar
Default Re: mini tub? how big without it? (M396 #00-011)
Cool :cool: lookin hood :cheers: I have a question about tire math and trying to putting a 335 tire inside a 12.5" wide fender. Isn't a 335/30 - 18 tire 13.1" wide? (335/25.4)
13.1 X 30% = 3.93" tall sidewall + 18" rim + 3.93 other sidewall = 25.86 tall tire.
Does that not also mean that the tire treads are sticking over the edge of the 11.5" wheel by 3/4" not counting sidewalls? :confused:
Old 01-08-2003, 02:26 PM   #7
M396 #00-011
CF Senior Member
Default Re: mini tub? how big without it? (vrumvrum)
The tire is made for a 12.0" rim. It will be pulled in a bit. Most look at this as a curbing protection feature. I doesn't look bad, I actually prefer the look. Mate the tire with a 275/35/18 in the front on a 9.5-10" rim. Look up CCW wheels for pictures as well as others on the CF.
Old 01-09-2003, 10:55 AM   #8
Red5
CF Senior Member
Red5's Avatar
I run a 17x12 ccw rim in the rear and plan on running 335s. Hope I can clear it. The guys at CCW seem to think it will work.
Red5 is offline   Reply With Quote
Old 01-10-2003, 01:46 AM   #9
vrumvrum
CF Senior Member
vrumvrum's Avatar
Default Re: mini tub? how big without it? (Red5)
I am interested in seeing the results. I don't understand, as in my previous question, how you can put a 13.1" wide tire inside a 12.5" wide fender. :confused:
Old 01-10-2003, 04:49 PM   #10
M396 #00-011
CF Senior Member
Here ya go.
This is CF member joecool's car.
Reload this Page mini tub? how big without it?
Tags
c5, corvette, dallas, mini, minitub, size, tires, tub, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pics Of Your Minitub 2MuchRiceMakesMeSick C5 General 11 03-25-2005 05:36 PM
COMPLETE DIY Mini-Tub, Wheel Offset, and Shock-Travel-Limiter INFO --> 97C5ENVY C5 Tech 32 03-12-2004 11:33 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
