Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-10-2002, 01:21 AM   #1
james holley
CF Senior Member
Default What Does Wheel Off Set Mean?
Will somebody 'splain this to me? By the way, what is the off set on the factory 16/9.5 wheels that came on my 87? Thanks.
james holley is offline   Reply With Quote
Old 12-10-2002, 12:43 PM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
Default Re: What Does Wheel Off Set Mean? (james holley)
James, "offset" is the distance that the bolt pad is from the actual centerline of the rim.
In other words, if you have a rim that is 8" wide, and there is 4" from the bolt pad to the back of the rim, and 4" to the front, the wheel has "zero" offset, since the bolt pad is "centered" in the rim.
Positive offset, is when the bolt pad is closer to the front of the rim. All front drive cars, as well as C-5 'Vettes and 4th generation Camaros have positive offset wheels.
Naturally, negative offset is the opposite. Remember all of the old jacked up muscle cars with the big tires that stuck out? Extreme negative offset.
I'm sorry, but I can't answer your factory offset question.
leadfoot4 is offline   Reply With Quote
Old 12-10-2002, 06:24 PM   #3
Todd@Tires.com
CF Senior Member
Todd@Tires.com's Avatar
Send a message via AIM to Todd@Tires.com
Your Vette came with a +39 offset on the 16x9.5 rears & +32 offset on the 16x8.5 fronts.
The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
Positive Offset
A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or "deep dish".
Note that extensive negative offset can potentially cause increased steering wheel kick-back and place additional stresses on the vehicle's entire suspension.
Please feel free to drop by or phone a store near you if you require additional facts about wheel offsets.
[Modified by Todd@Tires.com, 10:30 PM 12/10/2002]
Todd@Tires.com is offline   Reply With Quote
Reload this Page What Does Wheel Off Set Mean?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Got my ZR1 Rims in! Let me know how they look.. BMF42 C4 Tech/Performance 38 07-07-2004 11:59 AM
Dimensions of lowering wedges Sliding C4 Tech/Performance 12 12-18-2003 03:37 PM
17x11 wheels gojo C5 Tech 11 11-26-2002 03:06 AM
What Does Off-Set Mean? (Wheels) OHSIXX C3 Tech/Performance 16 08-31-2002 12:23 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
