Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
07 c6Z06 wheel failure
Old 05-30-2017, 09:20 AM
928nomore
928nomore's Avatar
Default 07 c6Z06 wheel failure
Had 2 front wheel failures this past weekend on track and I am wondering if it has happened before or why it happened, and most importantly how do i correct the problem.? The first rim cracked, i fortunately noticed it and came in and changed the wheel thinking it a fluke. The next day i had the wheel fly off while on track- fortunately no injuries and very little damage except to front splitter.
Any thoughts would be appreciated. Maybe its my set up? do have 2.5degrees negative camber was in a clockwise road course.
Any suggestion for stronger wheels? don't care about weight, just saftey,
All suggestions welcome, these are both 07 stock GM chrome wheels made by Speedline in italy.
928nomore is online now Report Post
Old 05-30-2017, 10:34 AM
64drvr
64drvr's Avatar
Received 1,871 Likes on 888 Posts
St. Jude Donor '15
Wow thanks for sharing. Do you hit the rumble strips? I've been happy with CCW Corsairs and recommend them. I'd also look at Forgeline, Finspeed, and BBS.
Old 06-01-2017, 07:57 AM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
For real driving enthusiasts there aren't many feelings that equal the excitement of running laps on a racetrack at their vehicles' performance limit. And while race tracks were once only accessible to race-prepared cars, today many car clubs and some professional driving schools allow drivers to learn more about high performance driving as they run their street cars (with relatively few modifications) on the same tracks as their racing heroes. For that matter, it is not unusual to have more track time (enough to drive several hundred track miles per day) at a typical club event or driver's school than most actual race weekends. And while it's common sense that track use will increase the wear on a car's tires, brakes and shocks, there are less obvious critical components that also wear out...like its wheels! Yes, wheels do wear out. Or better stated, they fatigue.
Because wheels are so critical to the driver's safety, top racing teams visually inspect their wheels at the track, monitor the total number of hours they are used, and crack test them on a periodic basis. Any wheel that shows signs of fatigue or age is discarded and replaced. Many professional race sanctioning bodies require that their race participants' wheels meet strict standards when new and that previously used wheels be recertified periodically.
Unfortunately, the same rigorous wheel inspection procedures are not typical for many driving enthusiasts who use their vehicles on the track. Maybe it's because wheels are typically so trouble-free that they are often overlooked. But if let go for too long, wheels subjected to high stress track conditions can fail.
When it comes to wheel fatigue, it is important to remember that it is caused by a combination of the frequency and magnitude of the stresses it encounters. While small stresses can be accommodated for thousands of cycles, large stresses accelerate the wheel's fatigue factor and the number of fatigue-free cycles is significantly reduced. So what is it about track use that reduces the life expectancy of wheels? Let's explore some of the important factors.
All wheels flex as they are driven around a corner. In normal street driving the amount of flex is minimal. However, since today's Track & Competition DOT tires almost match the performance of yesterday's racing tires, every corner that is taken at the limit of traction on the track causes significantly more flex. It's the combination of the extra tire grip and the resulting extra flex that fatigues wheels faster when used on the track.
During track use, wheels will often reach temperatures never encountered on the street as they help dissipate brake heat. This constant cycling between the ambient temperature and the extremes encountered on the track can increase the fatigue rate of alloy wheels.
In normal street driving, wheels are typically removed from the vehicle only when the tires are being rotated (typically every 5,000 miles) or replaced (typically every 25,000 to 40,000 miles). But when used on the track, wheels are typically removed from the vehicle at the start and finish of each day, as well as, anytime the vehicle's brakes or suspension are being serviced. Additionally DOT-legal competition tires wear out and are replaced much more frequently than normal street tires. These extra tire mountings and vehicle installations can increase wheel fatigue as they wear out the wheel's lug seats and the vehicle's lug nuts/studs or lug bolts/hubs.
So what should track drivers do to take better care of their wheels and minimize the possibility of wheel failure?
Make certain that the wheel's installation hardware is correct for the vehicle and in good condition. Since almost all of today's cars are designed with hub-centric wheels which transfer the vehicle's load from the center of the wheel to the car's hub (and allow the lug nuts/bolts to just hold the wheel against the hub), it is important that track wheels continue to be hub-centric to help distribute the forces encountered on the track. If an aftermarket wheel requires special centering rings to properly fit it to the hub, be sure they are installed correctly.
When any non-Original Equipment wheel or lug nut/bolt is used on the vehicle, it is important that there is sufficient thread engagement between the lug nuts/bolts and the vehicle's hub. It's acceptable to increase the thread engagement by installing longer wheel studs in the hubs after verifying that the lug nuts don't bottom out on the studs. However, if the vehicle uses lug bolts, they must maintain as close to the original amount of thread engagement as possible. Longer lug bolts may cause interference with the parking brake or other components inside the hub.
Always torque the wheel's lug nuts/bolts to the hub using a "star" pattern until the vehicle's correct torque value is reached.
Note: If wheel spacers that are thicker than the height of the hub are used, they also need to be wheel- and hub-centric to help distribute forces.
Drivers participating in track events must remain aware of their vehicle's normal characteristics throughout every on-track session. Any changes in their vehicle's normal performance and handling, or the presence of any unusual noise and/or vibration is cause for immediate concern and a thorough inspection of the vehicle should be done until the source of the problem is located and corrected.
At the beginning of each track session, drivers should concentrate on knocking noises and/or vibrations that could indicate a potential problem. While minor noises and/or minute vibrations may allow the driver to continue to the pits at reduced speed, noises and/or vibrations that suddenly appear, rapidly increase in intensity or become severe are cause for the driver to clear the circuit as well as, circumstances permitting, come to an immediate and controlled stop with regard to other drivers.
While it may seem innocent enough, straightening out the track by ditch-hooking corners and driving aggressively over the rumble strips and curbing will shorten wheel life. Drivers should also be wary of potential damage caused by off-track excursions that result in direct contact or bottoming of the suspension. One encounter with trackside curbing can be enough to damage the wheel and lead to failure.
At the end of every track day the wheels should be allowed to cool, should be cleaned front and back, and inspected for minute cracks, impact damage and runout. At the first sign of a crack appearing (regardless of size or location) or an indication the wheel has been bent, it should be removed from service and replaced with a good wheel.
Every time new tires are mounted, each wheel should be inspected to verify that it is round and true. If it is found to be bent, it should be removed from service and replaced with a good wheel.
If the wheel has been used for an extended period of time, you may want to have a local machine shop professionally crack test it in the off-season to ensure it can be subjected to another year of track use.
Wheels are a critical component to your car. Because they tend to fatigue slowly, periodic inspection will usually reveal the signs of aging and use (such as minute cracks in the wheels spokes or near the bolt holes) before they can become a serious problem. If overlooked, once a crack has formed it will concentrate the stresses in the weak area and allow the crack to spread until the wheel fails.
Lug nuts, lug bolts and wheel studs are designed to outlast the lifetime of a vehicle used for regular street driving. However, wheel hardware subjected to competition/track use typically experiences significantly more severe service conditions and a greater number of installation/removal cycles in one autocross/racing season. The condition of wheel hardware should be inspected frequently and replaced periodically.
It is important to note that track use and/or participation in racing voids the manufacturers' warranties of all street wheels.
Old 06-02-2017, 10:21 AM
928nomore
928nomore's Avatar
Thank you Luke, you make some very good points, However, I am still confused as to what is the right thing to do, I think i need to go to forged wheels with a 3000lb load testing capacity for the track, Called your shop but Tire rack does not sell any forged wheels in 18x9.5 Zo6 fromt sizes.
How strong are the Stock wheels? Would new stock wheels be as strong as Forged? I check my wheels before every run,( while checking tire pressures) but they have had a lot of cycles, just very strange that i would have 2 failures in one weekend on the same wheel.
Would you recommend just new stock rims? and change them more regularly? I am going to bite the bullet and go with a name brand forged rims but they are very expensive.
Old 06-04-2017, 09:46 PM
KFehling
KFehling's Avatar
Finspeed
Old 06-05-2017, 07:29 PM
stevebz06
stevebz06's Avatar
Are you torquing your wheels yourself or is a tireshop doing it for you? I've seen wheels installed with an air gun that were way over torqued.
Old 06-28-2017, 08:40 PM
exracer28
exracer28's Avatar
A method that will detect cracks in ALL non magnetic materials is called
Dye Penetrant Examination. It is simple enough that an engineer can do it but in the ral world there is training and certification required.
Clean & dry the area to be examined.
Apply the dye penetrant and wait 10 to 15 minutes which allows the dye to soak into any cracks.
Wipe off all the penetrant.
Spray on the developer which is a very fine powder.
The dye will have soaked into any crack will be visible with the developer, showing the location of most cracks.
Things can be x-rayed but its hard for me to justify using work equipment to check my wheels. I check my wheels every winter but I have access to some very good NDI equipment that I need to remain familiar with and that's my story and I am sticking to it. I do buy my own dye and developert. :-)
Old 11-21-2018, 07:34 AM
0Finspeed
Former Vendor
Finspeed's Avatar
Some very good points here. One of which is the extra loads and stress that a racing tire/DOT R Comp will generate on a wheel that a street tire simply will not. OEM wheels are simply not engineered for the loads that a race tire will generate on them. This is why we not only do extensive FEA testing in ANSYS on all our wheels, but we subject them to real world load testing in a lab on racing slicks, not street tires.
GoJuice505 (12-13-2019)
Old 11-22-2018, 02:38 PM
KFehling
KFehling's Avatar
I will echo what Finspeed said above. I have broken several Corvette stock wheels and moved to Finspeed and have not had any issues since. The nice thing about their wheels is that they are not only stronger, but lighter as well. I know several others here on the forum run their wheels as well with no issues.
To 07 c6Z06 wheel failure
Quick Reply: 07 c6Z06 wheel failure
