Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-27-2002, 07:00 PM   #1
Rob 2K1
CF Senior Member
Rob 2K1's Avatar
Default New Kumho Ecsta MX - Anyone tried these yet?
I will be in the market for new tires shortly and I was curious to see if anyone had tried the new Kumho Ecsta MX. I have heard good things about the 712, but I can't find much info on the MX. The MX comes in stock C5 sizes and the price is great. Anyone?
-Rob
Rob 2K1 is offline   Reply With Quote
Old 09-27-2002, 07:20 PM   #2
TA
CF Senior Member
TA's Avatar
Default Re: New Kumho Ecsta MX - Anyone tried these yet? (Rob 2K1)
I can't help you, but I've been wondering about them also
TA is offline   Reply With Quote
Old 09-28-2002, 03:33 AM   #3
gtsyellow
CF Senior Member
gtsyellow's Avatar
Send a message via AIM to gtsyellow
Default Re: New Kumho Ecsta MX - Anyone tried these yet? (TA)
friend has them on his Z06 in the front, says they blow the F1 supercar out of the water. so far that's all he's compared them against
gtsyellow is offline   Reply With Quote
Old 09-28-2002, 10:11 PM   #4
RX7 KLR
CF Senior Member
RX7 KLR's Avatar
Default Re: New Kumho Ecsta MX - Anyone tried these yet? (gtsyellow)
I have had mine for about 7000 miles. So far very little signs of wear, and I have a autocross alingment, lots of toe and camber. They ride nice, quite and great grip. I did some testing just for fun the MX vs the V700 race tire. The MX will pull 1.03lg the V700 1.21lg on my 89'. I have not had to much rain time, it is AZ, but saw some rain on the trip to Topeka and Utah, they were fine at hwy speeds. Can't beat the price, buy three of your brand or four Kumho's. I let my folks barrow them for a trip last week, the GSC's on their car were dead, they liked them. $150.00 at tirerack.com.
RX7 KLR is offline   Reply With Quote
Old 09-29-2002, 11:30 AM   #5
4GTWRK
CF Senior Member
4GTWRK's Avatar
I just put a set on my 96 a couple of weeks ago. I really like the grip, but I hate having to drive 10 miles to get them round again after setting a couple of days. I talked with Luke and he said that was common with them. I ordered a set of Firehawks to replace them and will probally try the MX's on the racer for rain tires.
Dave
PS - The side wall of the MX is really a pain to clean also, there's a lot of graphics on it with lots of grooves.
4GTWRK is offline   Reply With Quote
Old 09-29-2002, 11:53 AM   #6
Rob 2K1
CF Senior Member
Rob 2K1's Avatar
Default Re: New Kumho Ecsta MX - Anyone tried these yet? (84c4)
Thanks for the input so far! It sounds like the grip is great, but I'm not sure how I would like a tire that goes out of round after just a couple of days. Anyone else with info on the MX?
-Rob
Old 09-29-2002, 07:28 PM   #7
9T3JIM
CF Senior Member
9T3JIM's Avatar
Sounds like the MX is just like like the 712, great traction, but a poor choice as a cruising tire. I had a set for approx. 300 miles, ride comfort and low noise were a good thing, but the flatspotting, groove tracking and tire rebound vibration are beyond acceptable limits
9T3JIM is offline   Reply With Quote
Old 09-30-2002, 02:21 PM   #8
RX7 KLR
CF Senior Member
RX7 KLR's Avatar
Default Re: New Kumho Ecsta MX - Anyone tried these yet? (9T3JIM)
I have not seen a flat spot problem with mine... My car sits for weeks at a time.... What are your tires inflated to?
Old 09-30-2002, 07:47 PM   #9
9T3JIM
CF Senior Member
9T3JIM's Avatar
Default Re: New Kumho Ecsta MX - Anyone tried these yet? (RX7 KLR)
Had tires inflated to 33psi, really didn't try any other tire pressure. Usually my car sits for 2-3 weeks at a time. With the gsc's after a mile or two the flatspotting would be gone, but the Kumho's would take 15-20 miles. This was a AFS wheel/tire package. Can't say enough good things about AFS, after several conversations with Tim and Samantha at AFS they replaced the Kumhos with new Pirellis at no extra charge. The Pirellis are ok, very little wandering, the ride is not as good as the Kumhos but better than the GSC;s, the only negative is they sound like a pack of dogs howling at the moon, boy are these things loud
Old 09-30-2002, 08:52 PM   #10
RX7 KLR
CF Senior Member
RX7 KLR's Avatar
I use 35psi, but I am sure that would not make the difference. I have seen this happen with some race tirs, the soft rubber gets a flat spot from sitting. Need to do durometer test on the two tires and see if the Kumho is much softer than your new tires.
Old 09-30-2002, 11:08 PM   #11
9T3JIM
CF Senior Member
9T3JIM's Avatar
RX7 KLR, looks like you've done quite alot of tire testing, was wondering your impressions of how the MX is different from the 712 and why is it better. Thanks
Old 09-30-2002, 11:29 PM   #12
RX7 KLR
CF Senior Member
RX7 KLR's Avatar
I have never used the 712. I can tell you the MX is a softer compound than the 712. Also much larger tread blocks on the MX, so less tread movement in turns. The MX is molded at 9/32"nds I think the 712 is 12/32"nds. You should see much long life out of the 712 due to deeper tread and harder rubber as well as better wet traction due to more slots in the tread face. Dry performance is way better on the MX, per others testing, vs the 712. I have driven and autocrossed on the Gforce KD and I fell that the MX is very near the same level of performance at a way better price. On my car I am very happy with the MX. We are going to put a set of 712's on my folks 90', the want tire life not high performance, so I will be able to try them at a later date. The Tirerack.com is also a good source for reviews. I have also been told the Grassroots Motorsports magazine did a street tire shoot and the MX came out on top. I do not know the details, have not got a copy of the mag yet, but you might want to check that for another opion.
Old 10-03-2002, 01:28 AM   #13
Rob 2K1
CF Senior Member
Rob 2K1's Avatar
Thanks for all of the great info on the MX. Sounds like there are only a few people who have tried these so far. These seem to offer great performance and fall in line with my limited budget. Thanks everyone! Anyone else with info, please feel free to post it here.
-Rob
Reload this Page New Kumho Ecsta MX - Anyone tried these yet?
Tags
ecsta, flat, kuhmo, mx, spot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
Anyone tried out these new Firestone Firehawk "Wide Oval" tires yet? CentralCoaster C4 Tech/Performance 10 04-06-2005 02:35 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
