Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-26-2002, 07:25 PM   #1
8T1-7T9 BIONIC VETTE
CF Senior Member
8T1-7T9 BIONIC VETTE's Avatar
Default 2" Offset Trailing Arms What's Backspacing
I recently installed 2" Offset Trailing Arms.....Does this mean I can install wheels with an additional 2" and still clear any suspension parts on the inside?.....In other words my backspacing is 4".... can I install a 6" backspaced wheel now that the offset allows for 2 more inches? :confused: :seeya Thanks Cappy
8T1-7T9 BIONIC VETTE is offline   Reply With Quote
Old 09-26-2002, 08:01 PM   #2
74droptop
CF Senior Member
74droptop's Avatar
Default Re: 2" Offset Trailing Arms What's Backspacing (8T1-7T9 BIONIC VETTE)
Max back space is 5" the tire will hit the frame or sway bar before t-arm
74droptop is offline   Reply With Quote
Old 09-26-2002, 09:26 PM   #3
CF Senior Member
Default Re: 2" Offset Trailing Arms What's Backspacing (74droptop)
Okay 74droptop,
I'm ordering the 15X10 rims with 5" backspace.....this should keep me away from any suspension parts and still allow a 10 wide wheel to fit into my rear fender wells????? I'm trying to mount MT ET Streets 26X10.5 on these rims hope it all fits correctly.......Thanks for the reply.... :seeya Cappy
Old 10-01-2002, 03:43 AM   #4
TCracingCA
CF Senior Member
With offset trailing arms you can also cut the inner travel bumper bracket off of the frame you can gain a 1/2" more also have to relocate the emergency brake (done already on the offset arms), buy a shorter main leaf spring (difficult problem with the fiberglass units) one can be custom made, also exhaust mufflers a restriction. If you correct all of this you can run more offset beyond 5" but no more than 5-1/2 which can be done on at least a 81/2 rim or wider (10inch rim is 11" wide). If you get it wrong- use wheel spacers to bring it out without any harm as long as you have enough thread for lug nuts. Don't forget to account for the tire. Also the section width of the same tire will increase as you go to a wider rim.
Suggestion- take a big piece of cardboard and the tire O.D., Section width, Backspace and plot it out to exact 1:1 scale then cut out a representation of the actual fit (mockup) rotate it around on the spindle and see where you are. A piece of cardboard is alot less expensive than a set of rims and tires. Hope this helps ease your mind. Unfortunately because of the way they mounted the bodies. Check both side to be sure they are equal. I have seen a tire/rim combo work on one side but not on the other side of the car. Take it easy. Derek
[Modified by TCracingCA, 6:45 AM 10/1/2002] :seeya
[Modified by TCracingCA, 6:51 AM 10/1/2002]
TCracingCA is offline   Reply With Quote
Old 10-01-2002, 04:13 AM   #5
CF Senior Member
Default Re: 2" Offset Trailing Arms What's Backspacing (TCracingCA)
TCracingCA,
Thanks for the good info....It appears I'll be safe with 26" tall tires X 15 inch rims....10" wide and 5" backspacing....Welds Pro Star plus Wheels have these sizes in stock.....I'll try that cardboard thing first to be absolutely sure I won't end up with wheels for sale at my next garage sale.... :D :seeya Cappy
Reload this Page 2" Offset Trailing Arms What's Backspacing
Tags
arms, backspacing, c3, corvette, custom, offset, trailing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
295/50-15's whose got 'em - lets see 'em fauxrs C3 Tech/Performance 21 05-25-2003 09:08 PM
Calling anyone with 9.5" wheels on the rear......... Ryan77 C3 Tech/Performance 18 02-23-2003 06:35 PM
What size 17" wheels/tires on otherwise TOTALLY stock '63 SWC? JohnTheStigGalt C1 & C2 Corvettes 24 01-31-2003 09:19 PM
LPE Twin Turbo had the biggest damn tires I ever saw! chuckster C5 Tech 40 05-20-2002 12:50 AM
Widest wheel and tire combo with Vette Brakes offset trailing arms corvette kid 427 C3 Tech/Performance 13 03-03-2002 11:32 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
