Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-16-2002, 01:22 PM   #1
ModifiedC5
CF Senior Member
Default Those who have 315/30/18s on your C5
I know there has been allot of speculation. The math works out to be a difference of about 4.6% (shorter than stock). But has anyone put them on and had any problems? Would you go to 295/35 if you had to do it all over again?
Pls shed some light on the concerns of the impact of the shorter overall diameter as compared to stock dimensions on abs/active handling or anything else. Have you activated abs/active handling since you put the shorter tires on? Any issues?
What front size did you go with? I am considering the 275/35/18 FR and 315/30/18 RR on 18x9.5 and 18x11, respectively..
Any insight is appreciated.
thanx!
:seeya
[Modified by ModifiedC5, 10:24 AM 9/16/2002]
ModifiedC5 is offline   Reply With Quote
Old 09-16-2002, 05:32 PM   #2
Brutus0725
CF Senior Member
Default Re: Those who have 315/30/18s on your C5 (ModifiedC5)
Which tire maker makes 315/30/18's? I would buy them for my Z.
[Modified by Brutus0725, 5:30 PM 9/16/2002]
Brutus0725 is offline   Reply With Quote
Old 09-16-2002, 05:52 PM   #3
GTB/ZR-1
CF Senior Member
GTB/ZR-1's Avatar
Modified,
You will want to keep the front tires around 96% as tall as the rears--or you will have traction/AH issues. If your tire heights do not have the proper stagger, the traction control will kick on during semi-aggressive turning manuevers. I know this because our Auto-X setup is 275/40-17 front and 315/35-17 rear(same overall height), and the car will not--other than a straight line--allow you to drive aggressively unless TC is turned off.
You will NOT have any rubbing issues if you go w/ the 315's. You will want to go w/ a shorter front tire if you decide to go the 315/30-18 route...
Hope this helps,
George
[Modified by GTB/ZR-1, 2:53 PM 9/16/2002]
GTB/ZR-1 is offline   Reply With Quote
Old 09-16-2002, 07:40 PM   #4
RCswish
CF Senior Member
RCswish's Avatar
Send a message via AIM to RCswish
Default Re: Those who have 315/30/18s on your C5 (Brutus0725)
Quote:
Which tire maker makes 315/20/18's? I would buy them for my Z.
that is probably a typo (315/20/18), but if you meant 315/30/18....Pirelli P-Zeros are the only ones right now.
RCswish is offline   Reply With Quote
Old 09-16-2002, 08:30 PM   #5
Brutus0725
CF Senior Member
Default Re: Those who have 315/30/18s on your C5 (RCswish)
Thanks, that was a typo.. :crazy:
Old 09-16-2002, 09:11 PM   #6
ModifiedC5
CF Senior Member
Default Re: Those who have 315/30/18s on your C5 (GTB/ZR-1)
thanx George, what would be a more appropriate size in 18 to match the 315/30/18 rears?
[Modified by ModifiedC5, 7:27 PM 9/16/2002]
[Modified by ModifiedC5, 7:31 PM 9/16/2002]
[Modified by ModifiedC5, 7:41 PM 9/16/2002]
Old 09-17-2002, 12:25 AM   #7
GTB/ZR-1
CF Senior Member
GTB/ZR-1's Avatar
Ideally 275/30-18(just abt 96% of the 315's), but Pirelli does not make that size--yet... An alternative that may work is the 285/30-18, but it's a bit wide for a 9.5" rim, and it's abt 97+% height--although not optimum--it should work. I'm not sure if it will rub due to width--like I said, I have experience as wide as 275's for the front w/ no issues... Good luck
Old 10-03-2002, 09:53 PM   #8
motoracer
CF Senior Member
motoracer's Avatar
Send a message via ICQ to motoracer Send a message via AIM to motoracer
While I am waiting for comp tires to arrive to put on for auto-xing, I had some used (285/40/17) tires put on the stock front wheels and there was no rubbing.
Since I was running 265/35/18 on the stock rear wheels, I could not drive past 55 without setting off the traction control.
motoracer is offline   Reply With Quote
Old 10-30-2002, 05:15 PM   #9
Guest
Default Re: Those who have 315/30/18s on your C5 (motoracer)
Here is another question. If I put 18X9.5 all the way around is it possible to have 265/35/18 up front and 295/35/18 on the rears without any problems? I know it not optimal for the rear as a 295 calls for a 10 rim. But will it work?
Old 11-04-2002, 12:24 AM   #10
RCswish
CF Senior Member
RCswish's Avatar
Default Re: Those who have 315/30/18s on your C5 (nitrosuzie)
Sure, that will work fine. Go with a Supercar 295 on the rear as it has one of the more narrow tread widths.
Reload this Page Those who have 315/30/18s on your C5
Tags
18, 29535, 30r18, 315, 31530r18, alternative, c5, compare, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
AutoCross - What Air Pressure for Non-Runflats? RacerChris C5 Tech 9 07-07-2003 03:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
