Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2002, 07:33 PM   #1
Leo the Lion
CF Senior Member
Cruise-In II Veteran
Leo the Lion's Avatar
Default Left front tire "Cupping" what's the cause?
On my 01 cpe drivers side front tire is starting to cup on the outside edge. Anyone want to venture a quess why this is happening with 11500 miles on the clock? Is this alignment problems or air pressure. Front tires run with 30 psi hot. Wondered why the tires were so loud, man can hardly carry on a conversation with the wife.
Thanks in advance.
Bill Martone
Leo the Lion is offline   Reply With Quote
Old 08-08-2002, 02:01 AM   #2
mozin
CF Senior Member
Default Re: Left front tire "Cupping" what's the cause? (Leo the Lion)
You need an alignment. I hope the cupping is not too bad. :cry
Front tire cupping on the inside edge happens often with the EMTs. My EMTs were cupped with more than half the tread left. The tire shop suggested to trash them because they would not feel comfortable trying to resell them.
I am very pleased with my Michelin Pilot Sport A/S ZPs after 14K miles. :yesnod:
mozin is offline   Reply With Quote
Old 08-08-2002, 08:17 AM   #3
Leo the Lion
CF Senior Member
Thanks Moz........thats what I though. Will get that taken care of next week. If I can find someone I can trust to touch my car.
Bill Martone :cheers:
Old 08-08-2002, 09:58 AM   #4
olephart
CF Senior Member
olephart's Avatar
I agree on the alignment being the problem, but I think the air pressure could be adding to the already noisy (by design) tire. Probably speeds up the wear a little too.
30 psi hot is around 26-27 cold - seems too low. Ya might look at the sticker on the drivers door and use what it says - some people use a few pounds more.
Good luck.
olephart is offline   Reply With Quote
Old 08-08-2002, 11:51 AM   #5
TeamZ06
CF Senior Member
IMO pressure is too low and an alignment is needed, though a failing shock is also an extreme possibility. You should be running at least that pressure cold, not hot. Most truck tire shops can re-true a cupped tire that still has good tread on it. It is a machine that shaves the treadface while spinning the tire/wheel assy on the car. This is a std procedure for new retread tires, which is what most big trucks use. Getting harder to find them though.
TeamZ06 is offline   Reply With Quote
Old 08-08-2002, 09:17 PM   #6
Leo the Lion
CF Senior Member
Thanks guys for your thoughts. I'll add to the cold tire pressure and get an alignment done. The cupping is just visible to the eye, found it because I had wheels off to clean. Figured that was causing the noise.
Thanks again
Bill Martone
Old 08-08-2002, 09:18 PM   #7
Leo the Lion
CF Senior Member
Thanks again
Reload this Page Left front tire "Cupping" what's the cause?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
