Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-31-2002, 02:14 PM   #1
HwyStar
CF Senior Member
HwyStar's Avatar
Default Is there any way to measure the offset of a wheel?
I'm looking to buy some wheels and need to find out the offset for these wheels. How do we measure the offset?
HwyStar is offline   Reply With Quote
Old 07-31-2002, 02:26 PM   #2
The Dude
CF Senior Member
The Dude's Avatar
Default Re: Is there any way to measure the offset of a wheel? (HwyStar)
Backspacing is the distance from the mounting pad to the inside edge of the rim.
Offset is the distance from the mounting pad to the center line of the wheel.
Zero offset means the mounting pad is right on the center line.
Positive offset means the mounting pad is closer to the outside edge of the wheel.
Negative offset means the mounting pad is colser to the inside edge of the rim.
I think it would be tricky for a DIY-er to measure offset because the center line of the wheel is sometimes a point floating in space.
The Dude is offline   Reply With Quote
Old 07-31-2002, 09:14 PM   #3
SWCDuke
CF Senior Member
It's easy. Lay the wheel, with or without a tire mounted outside face down on a flat surface and lay a straight edge across the "top". Measure the overall width between the straight edge and surface and call this dimension "A".
Now measure from the straight edge to the wheel mounting plane and call this "B".
Offset = B - A/2, and this will yield the correct algebaic sign.
Duke
SWCDuke is offline   Reply With Quote
Reload this Page Is there any way to measure the offset of a wheel?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
driveline loss % vipervetteguy C6 Tech/Performance 12 08-29-2005 07:25 PM
More info on Dynatech Headers bgood C5 Tech 153 05-18-2004 07:46 PM
DIY toe on a C5 - Track width tomfoolery? JakeL Autocrossing & Roadracing 11 12-28-2003 04:30 AM
siamese or accel intake djbraxton C4 Tech/Performance 26 07-25-2002 11:26 PM
I need a little help with a plan for 11s '79ProwlerOrange Engine Mods 15 03-03-2002 07:17 PM
{CALLAWAY}Dymag wheel confusion>this ought to get intersting... *89x2* C4 ZR-1 Discussion 23 01-22-2002 12:20 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
