Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Out of round tires
Old 08-26-2014, 07:28 AM
Daleford
Daleford's Avatar
Default Out of round tires
I have had a shake in the front end of my car that the tire shop can't seem to eliminate with a wheel balance. They have balanced off the car and a fine tine balance on the car. Finally they say the problem is the RH front is out of round. I jacked the car up yesterday and used a micrometer with a spring loaded pointer. The RH is out 55 thousands. The LF is out 30 t. [Wrapped 2 layers of duct take around the tire at the center tread to provide a smooth surface to measure from]
Is this amount excessive?
Old 08-26-2014, 02:54 PM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
While your efforts are commendable I would recommend that you find a shop with a Hunter GSP 9700 Road Force balancer for a proper diagnosis.
Quick Reply: Out of round tires
