19's & 20's on a C5 Base?
I am definitely going to put new rims on my 2000 C5 Vert. My dilemma is do i stay stock size or do i go bigger.. i think the look of bigger rims is better but what about handling.. recalibrating the speedo, ride comfort?
also i see many forum members put the same size front and rear (not staggered) Ughhh whats the best way to go? Too many options. Right now i have Nittos as fat as i could fit on stock 17' 18's.. i like the ride... comfortable and very stable even in rain so maybe i should stay stock size... ughhhh
If I had to do over, i would stay at 18/19. Im currently running 19/20 and I regret it. The ride is so so and i break lose fairly easily if I don't pay attention. That's just me.
19s & 20s
thanks for telling me. that helps me a lot. the handling is obviously very important. i appreciate your taking the time to respond
-pete
-pete
This is my rear 20 in tire now
This was my 19 in tire
Speedo doesn't have to be off at all. When you move up in wheel size, you go with lower profile tires. If you choose the right tire size, the outer diameter will be the same as OEM and your speedo will be unaffected...
