Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-23-2002, 01:44 AM   #1
SvenOdin
CF Senior Member
SvenOdin's Avatar
Send a message via AIM to SvenOdin
Default Potenza S-03 Pole Position on Z06 stock rims???
I have the stock 2002 Z06 rims arriving this week, and I have been searching for tires. I have looked at the Goodyear Eagle F1 Supercar and the Toyo Proxes T1-S.
What I really want is the Bridgestone Potenza S-03 Pole Position. These appear to be the best all away around. The only problem is they do not come in P295/35 for the rears.
I'm thinking about going with them in the following sizes:
P265/40YR17 front
P285/30YR18 rear
I don't know much about tires and could use some advice. Would this setup be appropriate (17x9.5 front 18x10.5 rear Z06 rims), or would this cause problems
Appreciate some advice and guidance.
SvenOdin is offline   Reply With Quote
Old 07-23-2002, 09:58 AM   #2
Mark V
CF Senior Member
Mark V's Avatar
Default Re: Potenza S-03 Pole Position on Z06 stock rims??? (FOsteology)
Im currently using the S-03 Pole Position and love them. Im running a 285/30/20 rear and a 245/35/19 front. They are the best tires I have had hands down. The ride is smooth and not nearly as loud as the run-craps. Handling is better too. I dont think you can go wrong with these tires.
As for the sizes your looking at...im not sure but I will calculate the overall diameter and let you know if they will work or not.
Ok the following are the calculations for over all diameter as I worked out. Im not a math wiz so you might want to double check but I think they are close...
Stock C5 Diameter
245/45/17 front------- 25.681
275/40/18 rear------- 26.661
Yours
265/40/17 front------- 25.346
285/30/18 rear------- 24.732
After looking at the above you can see that your choice might not be the best due to the rear being smaller over all than the front. This will most likely affect your ABS, Traction Control System, and maybe your Speedo too. The onboard CPU looks at the sizes of each to run its systems and the difference needs to be as close as possible to the stock set up.
As I said you might want to double check my numbers and info but I think im on point with this.
Good luck.
:cheers:
[Modified by Mark V, 8:16 AM 7/23/2002]
Mark V is offline   Reply With Quote
Old 07-23-2002, 01:10 PM   #3
SvenOdin
CF Senior Member
SvenOdin's Avatar
Default Re: Potenza S-03 Pole Position on Z06 stock rims??? (Mark V)
Thanks.
But my stock Z06 is:
P265/40ZR17 front
P295/35ZR18 rear
How do you do the calculations??? :confused:
Old 07-23-2002, 06:47 PM   #4
Mark V
CF Senior Member
Mark V's Avatar
Sorry didnt know it was a Z06, thought you were getting Z06 rims on your C5.
The calculations is done like this.
265/40/17
265 x .40 = 106
106 x 2 = 212
17 x 25.4 = 431.8
431.8 + 212 = 643.8
643.8 / 25.4 = 25.346 overall diameter
Old 07-23-2002, 07:03 PM   #5
SvenOdin
CF Senior Member
SvenOdin's Avatar
Thanks for the advice, comments, and e-mails. Everyone has been very helpful.
Since I've already shelled out 1200 on the rims, and will shortly drop 900+ on tires, I'm simply not in a position to upgrade to 18's all around (although I'd like to!).
Will now have to decide between the Goodyear's and Toyo's.
Searching through the forum it appears that it's almost a 50/50 split on which one to go with. I think the only advantage one manufacture has on the other is price.
Many thanks!
:cheers:
[Modified by FOsteology, 8:52 PM 7/23/2002]
Old 07-24-2002, 02:41 AM   #6
threeimpalas
CF Senior Member
Here's an EXCELLENT site for calculating tire sizes.
http://www.miata.net/garage/tirecalc.html
threeimpalas is offline   Reply With Quote
Old 07-24-2002, 06:10 PM   #7
SvenOdin
CF Senior Member
SvenOdin's Avatar
Default Re: Potenza S-03 Pole Position on Z06 stock rims??? (threeimpalas)
Threeimpalas,
Thanks! That helps tremendously!
:cheers:
Old 07-24-2002, 08:31 PM   #8
Nitro-C5
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08
Nitro-C5's Avatar
Great site thank-you...
Nitro-C5 is offline   Reply With Quote
Old 08-01-2002, 09:26 AM   #9
NastyC5
CF Senior Member
NastyC5's Avatar
Default Re: Potenza S-03 Pole Position on Z06 stock rims??? (SvenOdin)
S-03 Pole Positions rock :yesnod: I have them in 275-30-19 and 285-30-20
NastyC5 is offline   Reply With Quote
Old 08-01-2002, 03:22 PM   #10
EricJ
CF Senior Member
Cruise-In III Veteran
EricJ's Avatar
I have the Potenza 03 285/30/18's all the way around and I love the way they feel. The only problem you might run into is that your front tire/wheel diameter is going to be larger (about 1/2") than your rear tire/wheel diameter and this may not handle or look right.
EricJ is offline   Reply With Quote
Old 08-05-2002, 07:25 AM   #11
TeamZ06
CF Senior Member
The Bridgestone spec sheet lists the diameters:
265/40-17: 25.3"
285/30-18: 24.8"
The Z06 SCCA autocrossers run the Kumho Escta DOT race tire as a rain setup using 275/40-17 front and 285/30-18 rear; they pretty much kick everybodies butt in the rain with that size combo. However, if the diameter difference is a concern, you could drop back one size up front for a closer fit without giving up much:
255/40-17: 25.1" diameter, 9.4" treadwidth
285/30-18: 24.8" diameter, 10.5" treadwidth
vs:
265/40-17: 25.3" diameter, 9.7" treadwidth
I'd say it's pretty much your choice.
ps: it's always better to use the manufacturer specs rather than a calculator, the size rating is an approximation at best. You can usually find the specs on http://www.TireRack.com
Mark
[Modified by TeamZ06, 4:29 AM 8/5/2002]
TeamZ06 is offline   Reply With Quote
Reload this Page Potenza S-03 Pole Position on Z06 stock rims???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Potenza S-03 Pole Position on Z06 stock rims??? SvenOdin C5 Z06 Discussion 17 07-26-2002 08:45 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
