Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2002, 02:47 AM   #1
reyderz
CF Senior Member
reyderz's Avatar
Default Why does one tire wear on the outside?
The front driver side is wearing on the outside and the other front tire is not. Anyone know what causes this?
reyderz is offline   Reply With Quote
Old 07-18-2002, 04:08 AM   #2
Patrick96LT4
CF Senior Member
Cruise-In II Veteran
Patrick96LT4's Avatar
Send a message via AIM to Patrick96LT4
Default Re: Why does one tire wear on the outside? (reyderz86)
Worn or damaged suspension component(s) or a bad alignment.
Patrick96LT4 is offline   Reply With Quote
Old 07-19-2002, 06:47 PM   #3
Hellraiser
CF Senior Member
Default Re: Why does one tire wear on the outside? (Patrick96LT4)
Patrick is right. Take it to a shop for an allignment check. You should be feeling a vibration in speeds over 60 miles.
Hellraiser
Hellraiser is offline   Reply With Quote
Old 07-23-2002, 11:16 PM   #4
VetNutJim
CF Senior Member
Cruise-In I Veteran
VetNutJim's Avatar
Default Re: Why does one tire wear on the outside? (Hellraiser)
Re: Alignment
Bad alignment doesn't mean vibration.
Sounds like for some reason the camber setting is way out of specs on the side that's wearing abnormally.
Hopefully it won't mean a damaged upper or lower control arm.
You'll need a good FOUR WHEEL alignment that starts in the rear with the thrust angle,rear toe and camber. No caster adjustment on the rear.
Shouldn't be too difficult to get the problem fixed.
Good luck with it.
VetNutJim is offline   Reply With Quote
Reload this Page Why does one tire wear on the outside?
Tags
tire, wear
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
