07-17-2002, 11:46 AM
CF Senior Member
Will Sawblade 91-93 ZR-1 rims fit my 1991 w GS Flares?
Okay I'm sure this has been asked before, though I did a search for the info and couldn't seem to find anything on it.
I won't to put 1991-1993 ZR-1 sawblade style rims on my 1991 C4, which is not a ZR-1. Will they fit with the use of the GS flares?
Much Thanks
07-17-2002, 01:32 PM
CF Senior Member
St. Jude Donor '05-'06
Re: Will Sawblade 91-93 ZR-1 rims fit my 1991 w GS Flares? (tgroghan)
Yes, I have both on my car (ZR-1 Rims and GS Flares).
But I'll be getting rid of my sawblades soon for ZR-1 A-molds.
07-17-2002, 04:47 PM
CF Senior Member
Re: Will Sawblade 91-93 ZR-1 rims fit my 1991 w GS Flares? (Coupe89)
If you use a ZR-1 36mm offset instead of a Grand Sport 50mm offset,the tires will stick out past the GS flares.
07-17-2002, 07:40 PM
CF Senior Member
Re: Will Sawblade 91-93 ZR-1 rims fit my 1991 w GS Flares? (USAZR1)
Mine didn't stick out
07-17-2002, 09:11 PM
CF Senior Member
I stand corrected. Didn't realize the flares were that wide.
07-18-2002, 11:30 AM
CF Senior Member
Thanks for the great pictures... my faith has been restored! Time to get the flares and get the rims all finished up!
Thad
07-19-2002, 11:41 PM
CF Senior Member
Do you have pictures from the back and the side? I am thinking about the same set up - Wider is better!
07-20-2002, 04:00 AM
CF Senior Member
Re: Will Sawblade 91-93 ZR-1 rims fit my 1991 w GS Flares? (joalyons)
I'll try to take some tomorrow...
07-22-2002, 02:09 AM
CF Senior Member
Tags
1991, 93, blades, corvette, fbody, fit, mag, offset, sawblade, style, tires, wheel, wheels, zr, zr1  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
