07-17-2002, 11:05 PM
CF Senior Member
Re: renewing rims (jonny4523)
OK Jonny, I put a used set of 82's on my CE and had to "restore" them. Here's what I did, but I removed all of the clear coat as well.
You can remove the clea coat with checmical strippers, but I used #400 sandpaper, going around the rim. I followed that up with # 600 and finally #1500. This process stirips all clear coat off and you will also take the scratches out
Then I went to work with mother's wheel/mag cleaner to polish them.
I finally used a 4 1/2 grinder with buffing wheel and jewlers rouge to high polish them. Now they look like chrome, but it did take me about 3 hrs a wheel.
