Formula 43 Wheels The NEW Standard in 3 Piece Wheels
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Formula 43 modular wheel center sections use a Rotary Forged process that results in a superior tighter, circular grain structure. The rotary forged center section begins life as a cylinder of billet. The billet is then heated and placed into a die in the rotary forging machine. The die spins the billet at 300 RPM while the billet is pressed from above at a 5 degree angle. The material then flows in a circular pattern into the die. The new forging is then heat treated, quenched and aged to T6 standards. The end result is a rotary forged center section that has stiffer spoke dimensions, lighter weight and a quicker moment of inertia.
The Spin-Form process developed by Formula 43 is a specific method in spinning 6061 aluminum circular sheets into 2 piece rim-halves. The computer controlled German spinning machine uses four rollers to form the inner and outer rim-halves on tooling designed in the shape of each rim-half. The Formula 43 method is a three step process:
(1) spinning the part.
(2) heating and aging the 6061 rims to T6 condition and
(3) re-calibrating the rim-half after heat treating to ensure a very low run-out of the part.
Along with the Formula 43 process, several changes to the rims have been made to better fit and perform with today's modern racing and sports cars:
1. Improved safety bead on both inner and outer rims to ensure proper seating of the tire so that the tire will stay mounted to the rim in the event of impact or loss of air pressure.
2. Improved rim contour to help ease tire mounting and bead seating.
3. Added material in specific areas of the rim-half for additional strength and stiffness.
4. Drop center contour updated for proper TPMS fitment and installation without having to add additional brackets or modifications.
Used By many of the top Grand AM RACE TEAMS
Including
Stevenson Motorsports Camaro, Automatic Racing's BMW and Aston Martin & Others
Formula 43 Rad 10 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6 Laguna Gray
RAD 10
Ten radial spokes are aligned with each lug pocket and each spoke has an opposing spoke resulting in maximum strength, minimal deflection and long service life. Forged center section and AL6061-T6 German Spin-Form modular rims standard
Package Includes
(2) Front 18x11 Rad 10
3 piece Wheels Correct Backspace C6/ZO6
Large Brake Kits Will Fit
(2) Rear 18x13 Rad 10
3 piece Wheels Correct Baclspace C6/ZO6
$3840 delivered lower US
http://www.xplosiveperformance.com/F...y-_p_3508.html
Formula 43 Rad 5 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6
Traditional “Five-Spoke” design with a new 21st century look. Each side of the RAD 5 spokes feature our sculpting to reduce weight and also add additional dimensional definition to the wheel. An excellent choice for a wide range of applications. Forged center section and AL6061-T6 German “Spin-Form” modular and blind fastener technology standard.
Package Includes
(2) Front 18x11 Rad 5
Large Brake Kits will Fit
(2) Rear 18x13 Rad 5
http://www.xplosiveperformance.com/F...6-_p_3513.html
Formula 43 Rad 6 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6
Split-Six Spoke design with a splayed “V” and large chamfers on each spoke. Each “V” is balanced with an opposing “V” keeping the wheel design symmetrical. An excellent choice for a wide range of applications. Forged center section and AL6061-T6 German “Spin-Form” modular rims and blind fastener technology standard.
Package Includes
(2) Front 18x11 Rad 6
(2) Rear 18x13 Rad 6
Formulas 43
Any Style Wheel RAD 5,RAD 10, RAD 6, RAD 5S
any Standard Options
Package Includes
(2) Front 18x10
(2) Rear 19x12
$3890 delivered lower US
Formula 43 Rad 10 19x11/19x13 Set of 4 05-13 Corvette ZO6/C6/ZR1 Laguna Gray
RAD 10
Package Includes
(2) Front 19x11 Rad 10
3 piece Wheels Correct Backspace C6/ZO6/ZR1
Large Brake Kits will Fit Clears ZR1 Calipers
(2) Rear 19x13 Rad 10
3 piece Wheels Correct Baclspace C6/ZO6/ZR1
$4095 delivered lower US
Formula 43 Rad 5 19x11/19x13 Set of 4 05-13 Corvette ZO6/C6/ZR1
Package Includes
(2) Front 19x11 Rad 5
(2) Rear 19x13 Rad 5
Formula 43 Rad 6 19x11/19x13 Set of 4 05-13 Corvette ZO6/C6/ZR1
Package Includes
(2) Front 19x11 Rad 6
(2) Rear 19x13 Rad 6
http://www.xplosiveperformance.com/F...6-_p_3518.html
ZR1 On RAD 10 Black Centers Polished Lip
Hoosier R6 Race Compound
Note center caps removed for track
EARN YOUR REWARD POINTS FOR FUTURE PURCHASES EARN $1.00 for every $10.00 Spent
ORDER ON LINE AND SCHEDULE YOUR INSTALL
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
#33
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
#34
Former Vendor
St. Jude Donor '13
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
MADE IN THE USA
in
Livonia Michigan
Including
RAD 10
Package Includes
Package Includes
Package Includes
Formulas 43
Package Includes
(2) Front 18x10
(2) Rear 19x12
RAD 10
Package Includes
Package Includes
Package Includes
Join us on Facebook
