c5 17x11 36mm offset square setup?
I have a set of 17x11 zr1 wheels with the 36mm offset with 315-35 nitto nt01 tires for autoX. I used these for a square setup on my 4th gen camaro. I have found that most people recommend the 50mm offset for fitment on the C5, But say it rubs slightly on the front arms and brake ducts. Should I put the 36mm for sale or run them on the C5? Does anyone run the 36mm square offset on C5? *This is for track use only*
RUN THEM OR SELL THEM FOR A 50MM SET?
