Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
What pressure should I use on my BFG 315 drag radials??
Old 06-07-2002, 07:38 PM
Cha Cha
Cha Cha's Avatar
Default What pressure should I use on my BFG 315 drag radials??
I have a brand new pair of 315's on 17/11 rims.. What tire pressure would you suggest???
Old 06-07-2002, 11:28 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: What pressure should I use on my BFG 315 drag radials?? (Cha Cha)
Start at 24 lbs and see how they work.
Old 07-19-2002, 02:33 AM
Bgreenard
Go Fast
Support Corvetteforum!
Bgreenard's Avatar
Default Re: What pressure should I use on my BFG 315 drag radials?? (mackeyred96)
I just tried out my new set of 315 35 17 drag radials last week at the track in Memphis. I couldnt hook with 20lbs. My best 60ft was 2.18. Any suggestions??????
BG
Old 07-29-2002, 12:37 AM
REDGAR
REDGAR's Avatar
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Re: What pressure should I use on my BFG 315 drag radials?? (Bgreenard)
I have had good success at 21 PSI on mine.
Be sure you get a fair burnout on them to make them sticky.
Old 07-29-2002, 01:30 AM
Bgreenard
Go Fast
Bgreenard's Avatar
Default Re: What pressure should I use on my BFG 315 drag radials?? (REDGAR)
Thanks, I need to work on doing a better burnout, Im being told I need to go until I see some white smoke.
BG
Old 07-29-2002, 10:22 AM
REDGAR
REDGAR's Avatar
CI VI Drag Champ!
Oh yes, white smoke is a must.
Take a look at these pics of my car the red c5 with 6467 on the glass at http://www.corvettechallenge.info/2002/event5
To What pressure should I use on my BFG 315 drag radials??
Quick Reply: What pressure should I use on my BFG 315 drag radials??
