Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Tires on concrete
Old 09-23-2012, 10:18 AM
missinmyvette
missinmyvette's Avatar
Default Tires on concrete
I saw a post inquiring about running old tires that still look good and if this was a good idea. I just wanted to post what I was told about cars that sit alot in the garage on concrete. I was told that concrete will suck the moisture out of the rubber leading to dry rot. It sounded good to me so my tires sit on 1/2" plywood just in case. Does this sound reasonable or is the wood worse?
Old 09-24-2012, 07:17 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
You should be OK. I guess if you really wanted to be sure that the porosity of the wood doesn't draw any moisture from either the tires or the concrete, you could coat the wood with polyurethane...
Old 09-24-2012, 08:16 AM
my50thAE
my50thAE's Avatar
I have also seen people put carpet pads or rubber mats under their tires.
Old 09-24-2012, 07:01 PM
leadfoot4
leadfoot4's Avatar
True....I use old carpet cut into squares.
Old 09-25-2012, 12:41 AM
missinmyvette
The carpet would be easier to deal with than the wood, I think i'll switch.
To Tires on concrete
Quick Reply: Tires on concrete
