Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2002, 03:01 PM   #1
jungleboy
CF Member
Default C2 - Offset Trailing Arms - Max rear tire/wheel size?
Without cutting body. Any help appreciated.
JB
jungleboy is offline   Reply With Quote
Old 06-05-2002, 07:23 PM   #2
Micky6
Junior Member
Micky6's Avatar
Default Re: C2 - Offset Trailing Arms - Max rear tire/wheel size? (jungleboy)
Just ordered a set, for my 65 BB clone ( sleeper car! ). I'll let you know.
I'm aiming for an 8.5" wheel w/ a 10.5" slick(strip) & P275/50-15(street). :D
Micky6 is offline   Reply With Quote
Old 06-07-2002, 03:05 PM   #3
jungleboy
CF Member
Default Re: C2 - Offset Trailing Arms - Max rear tire/wheel size? (Micky6)
Micky6
Many thanks. Waiting to see how you come out.
Old 06-08-2002, 04:59 AM   #4
bcwaller
CF Senior Member
bcwaller's Avatar
I am sure you can get wider than an 8.5" wheel. Maybe even a 10". I don't have my notes anymore, but I have 16x8 wheels (4.5" backspace - neutral offset) with 245/45/16 tires on my stock trailing arm (relocated e-brake cable). If teh offset arm gives you another 2", then you should be able to use a 10" wheel, but the tire will make a difference as well.
Van Steel says " you can use with the popular 10" wheels. That means that arms can accept 2" over the standard tire size and still give you the same recommended factory alignment. " here http://www.vansteel.com/Rebuild/offset.html
Remember, you will need a shorter spring if you go with the offset arm and fat tires. mine come pretty close to the spring as is.
bcwaller is offline   Reply With Quote
Reload this Page C2 - Offset Trailing Arms - Max rear tire/wheel size?
Tags
arm, arms, c2, corvette, offset, rear, trail, trailing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
