Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-24-2002, 12:31 PM   #1
Scoob
CF Senior Member
Scoob's Avatar
Default Tire diameter vs speedometer reading
If you increase your wheel/tire diameter, which way does that affect the speedometer?
For example, assume a 1.5% diameter increase. At a true speed of 65 mph what does my speedometer show? 66mph or 64mph?
Scoob is offline   Reply With Quote
Old 05-24-2002, 04:20 PM   #2
USAZR1
CF Senior Member
USAZR1's Avatar
Default Re: Tire diameter vs speedometer reading (Scoob)
A taller diameter tire has a larger rolling circumference and will increase the final drive ratio.(taller tires=taller gearing). So,your speedo will read slower.
USAZR1 is offline   Reply With Quote
Old 05-24-2002, 07:13 PM   #3
carter200
CF Senior Member
carter200's Avatar
Default Re: Tire diameter vs speedometer reading (USAZR1)
See your other post for the answer. USAZR1 is correct :yesnod:
carter200 is offline   Reply With Quote
Old 05-29-2002, 03:25 AM   #4
BCinPhx
CF Senior Member
BCinPhx's Avatar
Try this ...could help.
:) http://www.miata.net/garage/tirecalc.html
Courtesy of pkmoose
[Modified by BCinPhx, 11:26 PM 5/28/2002]
[Modified by BCinPhx, 11:29 PM 5/28/2002]
BCinPhx is offline   Reply With Quote
Reload this Page Tire diameter vs speedometer reading
Tags
reading, size, speedometer, taller, tire, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
