Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-22-2002, 08:09 PM   #1
AutoXr
Junior Member
Default Autocross Compound Tires correctly sized for Z06?
Does anyone know if Hoosier or Kuhmo etc. has any plans to produce DOT "sticky" tires correct to the OEM Z06 tire size?
Under the current NCCC rules, regular C5 sized tires are not legal for low speed or high speed events in the stock class. Only Goodyear seems to be producing a DOT soft compound tire in this size. As far as I can tell, no one has any. It forces the car out of stock class, or into stock street tire class.
AutoXr is offline   Reply With Quote
Old 05-23-2002, 01:03 AM   #2
kimvette
CF Senior Member
kimvette's Avatar
Default Re: Autocross Compound Tires correctly sized for Z06? (AutoXr)
AutoXr,
You might want to read the Spring 2002 Blue Bars page 20. There is a rulebook clarification on tires (November of 2000) to quote:
Q. When updating tires in ISH or IH are the tire sizes on each axle required to be the same configuration as came from the factory?
A. No! (vote 13-2)
Q. Can you mix the front tire of the regular C5 with the rear tire of the ZO6?On either the ZO6 or regular C5? (vote13-2)
A. Yes, if correct for axle.
:cheers: :cheers:
kimvette is offline   Reply With Quote
Old 05-23-2002, 01:13 PM   #3
AutoXr
Junior Member
Default Re: Autocross Compound Tires correctly sized for Z06? (kimvette)
It's good to hear that the rules were amended. I still would like to know if there are any plans to make a "sticky" Z06 tire size. The NCCC rule change potentially creates a larger market for the larger Z06 sized wheel/tire.
Reload this Page Autocross Compound Tires correctly sized for Z06?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
