Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2002, 11:21 PM   #1
jjcpj
Junior Member
Default Problem/question with aftermarket A mold wheels
I recently purchased a set of polished A mold wheels from Performance Wheel Outlet for my 96,(17 x 9.5's for the front and 17 x 11's for the rear)
I ordered (and received) the GS offset for the rears
The problem is that upon installing the rear wheels, I find I can't get the center caps to fit properly. The tip of the axel shaft extendes just far enough thru the wheel hub opening so that the cap actually hits the axel shaft.
In discussing this with Performance Wheel Outlet; their answer is for me to use some kind of spacer/shim between the wheel and rotor...
This does'nt seam right....any ideas/opinions??
jjcpj is offline   Reply With Quote
Old 04-02-2002, 03:38 AM   #2
MarkBychowski
CF Senior Member
MarkBychowski's Avatar
Default Re: Problem/question with aftermarket A mold wheels (jjcpj)
That doesn't sound right at all. I had a set of AFS A-mold copies for a while (same sizes as yours). Didn't run into any problems with the caps.
Is it just a small amount that they don't fit? If so, maybe you can grind some material off of the caps to clear?
I'd avoid wheel spacers if you can.
MarkBychowski is offline   Reply With Quote
Old 04-02-2002, 09:33 AM   #3
jjcpj
Junior Member
Default Re: Problem/question with aftermarket A mold wheels (MarkBychowski)
The cap is thin plastic, not able to grind at all...I only need about an 1/8"....
Can I grind the axel shaft?
Old 04-02-2002, 03:03 PM   #4
95DropTop
CF Senior Member
95DropTop's Avatar
Send a message via AIM to 95DropTop
There is no way this should be the case. I have GM original GS wheels on my 95 and do not have this problem. Sounds like maybe the offset is wrong??
95DropTop is offline   Reply With Quote
Old 04-02-2002, 07:03 PM   #5
Mikie C
CF Senior Member
Mikie C's Avatar
Owning a GMC Syclone, I know a lot of guys that have gone to these wheels on their Syclones-Typhoons and run into this same problem. They just grind the axel shaft , which is no biggie, as it doesn't cause any problems. HTH
Mike :seeya
Mikie C is offline   Reply With Quote
Reload this Page Problem/question with aftermarket A mold wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
