Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2002, 10:11 PM   #1
mrspice
CF Member
Default Thoughly confused!
Ok, I'm ready to place a wheel/tire order have talked to many people and now I'm confused on SIZE!!!! I want to NOT screw up my ABS or Active Handling but I want to go with a bigger wheel than stock for both front and back. I've talked to two different people at the tire rack and the one was real technical on the current offset of the car now with the original equipment. Who has really dug into this to make sure the car works the way it was intended to work and what size tires and wheels are you running? Any help here would be apriciated! :crazy:
mrspice is offline   Reply With Quote
Old 04-01-2002, 10:43 PM   #2
mrspice
CF Member
Default Re: Thoughly confused! (mrspice)
Sorry...I should have said I have a 2002....that might help! :yesnod:
Old 04-02-2002, 01:00 PM   #3
MilYellow02
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
MilYellow02's Avatar
Try this:
Either 18x9.5 in the front with 265/35's 18x10.5 in the rear with 295/35's
or 18x9.5 in the front and 19x10.5 in the rear with the same size tires as above :yesnod: Your AH and ABS will not be effected and you will maybe lose about 1 or 2 miles per hour accuracy on your speedo (no biggie)
If you need some recommendations on where to buy the wheels and what price range you want to be in, I can help there too. :cheers:
MilYellow02 is offline   Reply With Quote
Reload this Page Thoughly confused!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I did it RED VET 1987 C6 Corvette General Discussion 12 07-25-2005 12:57 PM
Bogus HP mods for the L98. I am so confused... chuckster C4 Tech/Performance 12 07-23-2002 09:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
