Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-30-2002, 09:05 PM   #1
John's vette
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
John's vette's Avatar
Default M/T ET Street vs. ET Drag
Can someone explain the difference to me. I can see the obvious, that the street sorta has a tread pattern. Are they also a radial? Why do so many people that have a drag setup with skinnies use the ET streets? Wouldn't traction be better with the ET drags? Only been to track a few times and I still have ALOT to learn.
John's vette is offline   Reply With Quote
Old 03-30-2002, 09:32 PM   #2
racewheel
CF Senior Member
Default Re: M/T ET Street vs. ET Drag (John's vette)
the et drag is not available in 16", m/t discontinued them shortly after releasing the et street ( thier testing showed no apprediable difference in grip between the 2)
racewheel is offline   Reply With Quote
Old 03-31-2002, 02:15 AM   #3
John's vette
CF Senior Member
Default Re: M/T ET Street vs. ET Drag (racewheel)
Been to your site several times and seen all the post from people raving about your set up. Did not realize your just down the street from me. I need to pay you a visit. Thanks for the quick reply.
Old 04-01-2002, 04:03 AM   #4
gcrouse
CF Senior Member
gcrouse's Avatar
The ET Drag is a real wrinkle-wall race tire that needs tubes. If you run it on the street at sustained speeds it will melt. The ET Street is DOT legal and you can drive to and from the track on it.
gcrouse is offline   Reply With Quote
Old 04-01-2002, 01:11 PM   #5
ralexand
CF Senior Member
ralexand's Avatar
Basically, ET Drags are full slicks for competition racing and ET Streets just barely DOT approved for Bracket classes
ralexand is offline   Reply With Quote
Reload this Page M/T ET Street vs. ET Drag
Tags
discontinued, street
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ET Street vs Drag radial for 380-450 RWHP Z06. Icevettez06 Performance Results 30 07-13-2004 11:59 PM
Street vs. Drag racing ROADAPPLE Drag Racing 36 05-07-2004 09:22 AM
MPH vs ET ??? Steve85 Drag Racing 13 03-11-2004 07:18 PM
Paging SoCal Z06 Drag Racers ZO6Les C5 Z06 Discussion 94 07-27-2003 04:50 AM
ET Streets - What rim and tire size is the best combo? MyFirstCorvette C5 Tech 38 07-10-2003 03:25 PM
Weight difference BFG Drag Radials vs. M/T ET Streets... GrandSportC3 Drag Racing 11 05-04-2003 12:04 PM
E.T. street vs. BFG drag radial life Face Drag Racing 19 08-22-2002 11:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
