Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-26-2002, 01:11 PM   #1
welprop
CF Member
welprop's Avatar
Default 17 x 11 A molds
I am looking for a set of track wheels and tires for my 93 coupe, preferably A molds. I currently have 17 x 9.5 rims on all four corners. What are the benefits to going to an 11" rim on the rear? Will the 315/35/17 on the rear rub the fender?
welprop is offline   Reply With Quote
Old 03-26-2002, 05:26 PM   #2
jay17
CF Senior Member
jay17's Avatar
Default Re: 17 x 11 A molds (welprop)
They will not rub the fender. I'm sure they handle better, I don't drive too hard, so I don't know for sure. They do look a lot :reddevil than stock 285s. Be sure to get GS offset (50mm) and not ZR1 offset. The ZR1 wheels stick out past the fender too much.
jay17 is offline   Reply With Quote
Old 03-27-2002, 12:27 AM   #3
89BP
CF Senior Member
Why not buy a set of 4 17x11" GS offset wheels, w/315's? This is the combo I run on my 89. If these are for just racing, they are perfect. If you run enough camber they will tuck completely under the fenders. The cornering grip is quite impressive over the 17x9.5" set up. Also, mine don't rub on the front or the rear, even at full lock.
89BP is offline   Reply With Quote
Old 03-27-2002, 10:50 AM   #4
welprop
CF Member
welprop's Avatar
Default Re: 17 x 11 A molds (89BP)
I will probably use them some for daily driving also I'm not sure if the wider front tires will give enough clearance for my brake ducts. Thanks for the input it is something to consider.
Reload this Page 17 x 11 A molds
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Do 17-11" rim stick out? sothpaw2 C4 Tech/Performance 21 11-24-2003 10:03 PM
Check Out The Fit On My New CCW Wheels superlund C4 Tech/Performance 26 10-11-2003 12:03 PM
A molds or AFS ? Midwest Vette C4 General Discussion 29 04-02-2003 08:42 PM
jackyl and there's a red c4 with black a molds.. where to get them??? J Z06 C4 General Discussion 13 08-09-2001 02:59 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
