Will they fit? 89 Vette wheels with 275/40/17 tires on a 99 Z28
Will the wheels and tires fit without any problems. The Z28 is not here to try them out physically.
Thanks,
Steve
Thanks,
Steve
Re: Will they fit? 89 Vette wheels with 275/40/17 tires on a 99 Z28 (dantos)
these wheels should fit.
I put a set of '90's rims on my '94Z28.
The only thing i can think of is that the inner lip of the wheel may need just a bit of grinding to clear the hub/lip of the rear wheels. I used a dremel and they fit right up. You may not actually need to do this, I heard it was only something necessary for LT1 fbodies.
check out my camaro pics at http://www.allnewhealth.com/mdawdy
