Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2010, 06:57 PM   #1
95redz
CF Senior Member
95redz's Avatar
Default CCW Classic custom powder coat inside
I just bought a set of CCW classics from the board here for drag use. I just got them powder-coated anthracite with clear added. Here are some pictures incase you ever want to change things up!
Click the image to open in full size.
95redz is offline   Reply With Quote
Old 02-13-2010, 08:53 PM   #2
drivinfast
CF Senior Member
Support Corvetteforum!
drivinfast's Avatar
Send a message via Yahoo to drivinfast
Those look great
What powdercoating shop?
see PM
i painted my c14s black pearl metalic but it chips off and i just repaint
drivinfast is offline   Reply With Quote
Old 02-14-2010, 06:37 PM   #3
doje
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
doje's Avatar
Did you disassemble the wheels first? Or did you have it all done as single pieces?
doje is offline   Reply With Quote
Old 02-16-2010, 07:05 PM   #4
95redz
CF Senior Member
95redz's Avatar
Quote:
They were just coated as a whole.
Old 02-19-2010, 04:27 PM   #5
doje
CF Senior Member
doje's Avatar
Quote:
Wow, I didn't think the sealant between the wheel pieces was able to hold up to the heat of the powdercoating oven.
Old 02-19-2010, 09:53 PM   #6
95redz
CF Senior Member
95redz's Avatar
Now I'm concerned. Maybe it didn't hold up?!?!
Coater inpsected them and said it was good to go....
Maybe the wheels will fall apart when I drive now!!
Old 02-20-2010, 03:44 AM   #7
doje
CF Senior Member
doje's Avatar
Wheels won't fall apart - they are bolted together. I would just worry about air leaks.
Old 02-20-2010, 08:02 AM   #8
leadfoot4
CF Senior Member
leadfoot4's Avatar
Not to screw up your day even more, but when you mount/dismount the tires, you have to be VERY careful not to disturb the seal between wheel center/halves. If this bond is damaged, the wheels might have to come apart for a "re-seal". Not a big deal, but if they were coated as a single unit,..........
leadfoot4 is offline   Reply With Quote
Old 02-20-2010, 02:20 PM   #9
95redz
CF Senior Member
95redz's Avatar
Quote:
So you are thinking I may see some leaks now??
Old 02-20-2010, 03:37 PM   #10
leadfoot4
CF Senior Member
leadfoot4's Avatar
It's hard to say, but I'd hate to see you mount your tires then have issues. You might want to add a "skim coat" of silicone over the seam between the wheel halves before you mount the tires. I know that CCW uses (or used to use) GE silicone, but I don't remember the particular part number off hand.
Old 02-20-2010, 03:56 PM   #11
95redz
CF Senior Member
95redz's Avatar
This isn't a bad idea at all. I'll maybe call up some wheel shops and ask around where I currently stand with this issue, if there is one.
Old 02-20-2010, 04:15 PM   #12
doje
CF Senior Member
doje's Avatar
I would definitely put a layer of silicone around the outside seam to reduce the chances of leaking.
- GE Silicone II Window & Door Sealant
***- Stock No GE5000 (Clear)
Old 02-20-2010, 05:30 PM   #13
95redz
CF Senior Member
95redz's Avatar
Thanks for digging this up for me. Currently on the wheels I can see the CCW installed silicone that was used. Any issues appying a big, mean, thick coat on-top of this already?
Old 02-20-2010, 05:48 PM   #14
doje
CF Senior Member
doje's Avatar
I wouldn't think it would be a problem. I would just make sure you completely cover the old stuff so you have a good seal. That's just a guess though.
Old 02-20-2010, 06:03 PM   #15
95redz
CF Senior Member
95redz's Avatar
Only one way to find out!!
Old 02-21-2010, 09:22 AM   #16
leadfoot4
CF Senior Member
leadfoot4's Avatar
You don't want to get too crazy with the silicone, because one of the tire's beads has to be able to slide over this part of the wheel, during the mounting process. If the bead is too thick, and the tire hangs up on it, and tears at it, this is how the leaks occur.
Old 02-22-2010, 06:40 PM   #17
95redz
CF Senior Member
95redz's Avatar
Good point. I'll take the wheels to a custom shop and have them look things over. Chances are I'll run a layer over the old seam.
Thanks!
Old 02-22-2010, 06:44 PM   #18
doje
CF Senior Member
doje's Avatar
Thanks!
Report back when all is done and the tires have been on for a week. Let us know if it worked.
Old 03-19-2010, 02:20 PM   #19
doje
CF Senior Member
doje's Avatar
Old 04-04-2010, 02:40 PM   #20
95redz
CF Senior Member
95redz's Avatar
I just had the rears mounted and there were no leaks that we could find nor see 4hrs later. I couldn't mount the fronts becuase the shop lost my valve stems for all 4 wheels and the place I went to didn't have a stem skinny enough to fit into the front (see my other thread).
I'll give these wheels a week to see how the air-pressure holds, being sure to test the pressure every day...probably every 15 minutes lol.
Reload this Page CCW Classic custom powder coat inside
Tags
c2, ccw, classic, coated, colored, corvette, custom, homepage, powder, powdercoat, powered, tires, vette, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
