Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2009, 08:42 PM   #1
NY~FX
CF Senior Member
NY~FX's Avatar
Default Z06 tire size requirements
I have set of 4 18" x 10.5" Z06 OEM wheels that I intend to use/dedicate to HPDE track sessions on my C5 FRC.
I intend to buy 4 Nitto NT05's for them.
My questions are;
Since the Z06 OEM tire sizes were originally:
Original Equipment Front Size 1: 265/40-17
Original Equipment Rear Size 1: 295/35-18
Specifically:
What size/s should I run with 18's all around - the goal for me is to get increased patch contact in front and allow for larger brakes, and allow for rotation.
How will the choices affect speedometer?
How will the choices affect Active Handling / Traction Control?
How will the choices affect the ratio of heights / stagger?
If I bolster the suspension with coilovers, beefier swaybars, wheel bearings and brakes - what other issues might I need to address to compensate for?
I know this issue has been thrown around before - any concrete answers would be helpful.
NY~FX is offline   Reply With Quote
Old 08-17-2010, 12:30 PM   #2
rfillmore
Junior Member
Default That is alot of questions, I'll try to help with a few.
My questions are;
Specifically:
The word from the GM guys is that traction control/active handling is expecting a bias between the front and the rear wheels. If you disturb remove the bias the active handling will engadge.
So. On a stock Z06 the bias is .7 inches or 2.7% larger diameter in the rear tires.
So if you are fixed on the Nitto NT05 then you have one choice. 315 on the back and 285 in the front. These will maintain the bias at .9 which will be fine.
your stagger will be the same...or .2 inches higher in the rear.
Active handling/traction control will not be effected.
Effect on the spedometer is neglidgeable.
Key is to make sure the overal diameter of the rear tires is larger than the front tires. .7 is stock that that is the number you want to try and stay close to.
That being said I run Nitto NT-01s and i have a 0.2 bias to ward the front and I've had no problems with active handling/traction control.
I don't know what the magic bias number is that screws up the handling.....but there is a magic number.
I hope some of that helped.
rfillmore is offline   Reply With Quote
Reload this Page Z06 tire size requirements
Tags
2009, c5, c6, control, corvette, dementions, diameter, original, size, sizes, stock, tire, tires, traction, wheels, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 04:33 AM
Some new info on the C6 Z06... Rick @ Les Stanford C6 Z06 Discussion 30 02-04-2005 07:52 AM
Talking With Tadge Juechter, Assistant Chief Engineer Rick @ Les Stanford C6 Corvette General Discussion 15 08-17-2004 10:53 PM
It is final decision time for wheels & tires - NEED YOUR HELP Sully C5 C5 Tech 26 02-29-2004 10:13 PM
Can someone list the differences between 2000 - 2001 C5 ? dumbkid C5 Tech 12 07-19-2002 08:17 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
