Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-14-2009, 10:04 AM   #1
kzx03p
Junior Member
Default Fixing damaged wheels - my experience
After upgrading my '05 to OEM Chrome Gumby wheels this spring, I bent my 2 left hand wheels going over an unseen pothole in Michigan at a road construction site on Square Lake Rd. at Telegraph late this summer. Fortunately, nothing else was damaged.
I Just wanted to let people know that if you find the right shop, bent wheels can be restored to factory specs without cosmetic damage! I took them to wheelrefinisher.com. They were confident in their ability to restore them, but I was not too hopeful - especially for the front wheel. I was told by several other wheel shops that the rear wheel could not be fixed due to the chrome plating, and that the front wheel could not be fixed due to the severity of the bend (several cm displaced on the inside edge, and looked "center-bent"). Wheel Refinishers told me that even fixing the front was no problem. The rear was bent less - probably < 10mm out of round.
When I arrived to pick them up, I was amazed! Not only were both wheels running true, but there was absolutely no cosmetic damage done during the straightening process. The price was reasonable as well.
Last edited by Allthrottleandsomebottle; 10-16-2009 at 08:40 AM. Reason: No links to non-supporting vendors
kzx03p is offline   Reply With Quote
Old 10-14-2009, 05:21 PM   #2
ztheusa
CF Senior Member
ztheusa's Avatar
They don't have the same strength anymore. Don't drive faster than you want to crash.
ztheusa is offline   Reply With Quote
Old 10-15-2009, 10:12 AM   #3
kzx03p
Junior Member
Default fixed wheels
I can't concede to that statement unless I see some numerical data showing yield strength before and after. It is actually possible that the strength has increased depending on the severity of the bend, the level of temperature used, and how quickly it cools, type of alloy, the original manufacturing process, and other factors. I would agree that it is also possible the strength could decrease. Many types of metal alloy products are produced by repeated heating, forming, and cooling. It's not necessarily bad. But without hard data, all one can say is that there is a potential risk of reduced strength.
The forged part of the wheel (spoke area) was not touched. Heating that area would almost certainly reduce strength.
Reload this Page Fixing damaged wheels - my experience
Tags
damaged, fixing, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
zaino vs maguires - which is best schilitj Car Care Discussion 53 01-16-2005 02:33 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
