Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-10-2009, 06:51 PM   #1
Spritle
CF Senior Member
Spritle's Avatar
Default C5's w/Big Brakes
What wheel size and offset are you guys running? I'm running C6Z brakes now and have to use a spacer that I'm not crazy about.
Pictures are appreciated.
__________________
'09 Z06
Spritle is online now   Reply With Quote
Old 07-19-2009, 10:06 PM   #2
Doug Harden
CF Senior Member
Doug Harden's Avatar
Similar problem here....have the C6 Z06 brakes on my '00 C5... and have gone through two sets of the POS Ace Z07 wheels....they last about three months before the chrome goes to hell......not a worse wheel on the market.
I desperately need different wheels (18") that fit over these brakes...and don't cost an arm and a leg......or come apart in a few months.
Anyone????
Doug Harden is offline   Reply With Quote
Old 07-20-2009, 11:28 PM   #3
ajg1915
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
ajg1915's Avatar
Anyone????
Good Luck. I got Wilwood 14" all the way around and trying to get rims to fit really sucks especially when you have a widebody like me.
In hindsight, I wish that I had just tubbed the rear.
It looks like 19" all the way around work with 305/19/30's and 345/19/30's
Now I just have to figure out what rims.
ajg1915 is offline   Reply With Quote
Old 07-21-2009, 11:18 AM   #4
COR Wheels
CF Senior Member
COR Wheels's Avatar
ajg seems like you're either going to have to go forged. As for the rest of you guys. Check out our site and let me know if anything catches your attention. www.corforged.com
COR Wheels is offline   Reply With Quote
Old 07-21-2009, 02:20 PM   #5
Doug Harden
CF Senior Member
COR...any idea which of your wheels fit our situation?
Old 07-21-2009, 02:57 PM   #6
20ngone
CF Member
20ngone's Avatar
i also have wilwoods all around. i went with ccw c140's, 18's on all four. i also did a minitub and put 345's mt on the rear. ccw c140's fit perfect. they have plenty of room for the big calipers.
20ngone is offline   Reply With Quote
Old 07-21-2009, 03:22 PM   #7
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
Quote:
Unfortunately I went with a wide body and not the tub, so C140's won't work. I need 19" rims and CCW doe not have too many for me to select from due to the widebody.
Once I get the car back together again, I'll see what's out there and go from there.
__________________
RIP 2001 ACP Custom FRC Stealth Wide Body
Parts for Sale Here
http://s61.photobucket.com/albums/h7...ale/?start=all
Old 07-21-2009, 03:54 PM   #8
Jack R. Stein
CF Senior Member
Jack R. Stein's Avatar
Send a message via AIM to Jack R. Stein
Check out LG Motorsports World Challenge wheels in C6/Z06 sizes. I have them on my C5 with the huge StopTech brakes and they made an offset that fit the fronts (18 X 10) fine and a (19 X 12) that fits the rear huge brakes as well! www.lgmotorsports.com and ask for Bobby! Hope this helps
Jack R. Stein is offline   Reply With Quote
Old 07-21-2009, 04:11 PM   #9
Spritle
CF Senior Member
Spritle's Avatar
Quote:
So you have C6Z sized wheels on your C5? Sorry to ask, but do you have any pictures? I wanted to know how these would look.
Old 07-21-2009, 04:12 PM   #10
Jack R. Stein
CF Senior Member
My car is currently in the shop getting some body mods installed and painted, so no pictures at this time. Sorry, but they do look awesome!
Old 07-23-2009, 12:33 AM   #11
JustinStrife
CF Senior Member
JustinStrife's Avatar
Justinstrife justinstrife unholy z06
Send a message via AIM to JustinStrife Send a message via MSN to JustinStrife Send a message via Yahoo to JustinStrife
Tough to find OEM looking wheels that clear.
I'm running 3/8" spacers upfront on 19x9.5" c5z wheels and dropping down to 18x9.5's. Wish I didn't have to run the spacers but didn't have any choice there was no way the wheel spokes could clear those massive calipers.
Check out those calipers almost up against the spokes with the 3/8" spacers.
JustinStrife is offline   Reply With Quote
Old 07-27-2009, 08:11 PM   #12
haikun
CF Senior Member
haikun's Avatar
Quote:
Did you need to tub the rear to get the 12" wheels or widen the rear body ? Looking for options to use on the track that will take Stoptech's big brake (ST40/ST60) on a C5 Z06 with 19/18" and enable be to use 335 in the rear without modifying like tubbing.
/Hakan
haikun is offline   Reply With Quote
Old 07-28-2009, 02:35 AM   #13
ajg1915
CF Senior Member
St. Jude Donor '08
ajg1915's Avatar
Quote:
/Hakan
335's are not going to fit under the stock fender without a tub or widening the rear fenders. You especially don't want the tires sticking out if you plan to track the car as it will sand blast the paint off your fenders.
Old 07-28-2009, 10:34 AM   #14
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Allthrottleandsomebottle's Avatar
My HREs on the 97' & 00' vert are offset for big brake kits
NOTE, my 97' is tubbed
97'
HRE 18 x 12 545 +74mm offset, I run 345/35/18,345/30/18 & 335/30/18s tires
HRE 18 x 9.5 545 +58mm offset
Here is my Website on the above wheels:
http://temp.corvetteforum.net/c5/30s/index15.shtml
00'
HRE 18 x 9.5 545 w/ clear center +58mm w/ new 275/35/18 BFG KDWs,
HRE 19 X 10" 545 w/ new BFG KDW2 295/35-19
Allthrottleandsomebottle is offline   Reply With Quote
Old 07-28-2009, 12:46 PM   #15
COR Wheels
CF Senior Member
COR Wheels's Avatar
All our wheels are made to clear big brakes. You just let me know exactly what brakes with dimensions, and measurements and I'll build you what ever you like ;-)
Reload this Page C5's w/Big Brakes
Tags
big, brakes, c4, c6, challenge, clear, corvette, hre, lg, motorsports, offset, rear, size, wheel, wheels, world, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Will Wilwood Fronts w/o rears be a noticeable difference... urslooow Autocrossing & Roadracing 48 02-20-2004 08:22 PM
LPE TT c5 vs supra turbo dyno!! r1hooligan C5 Forced Induction/Nitrous 134 09-06-2002 08:10 PM
C4 people w/ Big Brakes--how is your pedal & stopping power??? C5 like??? GTB/ZR-1 Autocrossing & Roadracing 13 06-26-2002 11:06 PM
STOP TECH Big Brakes for serious drivers davidfarmer Autocrossing & Roadracing 48 04-30-2002 10:26 PM
"Superlite" 6 Piston Big Brakes for $1200 - Wilwood's Challenge To Us! rbeckham Autocrossing & Roadracing 77 04-27-2002 03:20 AM
"Superlite" 6 Piston Big Brakes for $1200 - Wilwood's Challenge To Us! rbeckham C5 Tech 17 04-10-2002 05:45 PM
BIG BRAKES!!!!! HOLY SHHHH....Check it out...... DARTH VETTER C5 Tech 63 11-18-2001 07:47 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
