Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2009, 12:27 PM   #1
63_GrandSport
CF Senior Member
63_GrandSport's Avatar
Default Back spacing for c3?
I am getting the 2in offset trailing arms for the rear of the car. I want to put 10in wide wheels in the back. Do any of yall know the back spacing for this size wheel. How wide of a tire can I fit aswell?
Adam
63_GrandSport is offline   Reply With Quote
Old 06-03-2009, 06:07 PM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
If I remember correctly, the OE 8" rims had a 4" backspacing, So, if you're going with a 2" offset trailing arm, I would think you could SAFELY put a rim on the car with at least another 1.5" of backspacing. So, maybe a 10" rim with 5.5" backspace? Maybe a 275/60/15, or 295/50/15 tire?
I know a lot of people go to 17" or 18" rims, to get both a wider tire, as well as the higher speed rating. However, and this is just my opinion, the smaller diameters of these tires look out of place on a C3, since the smaller tires don't fill up the wheel opening as well as the taller, 60 series tires did......
leadfoot4 is offline   Reply With Quote
Old 06-04-2009, 04:53 AM   #3
63_GrandSport
CF Senior Member
I think you are right. I want to run a 60 series on it and was hoping to maybe go as wide as a 305. I was looking at some 15x 10 for the back so it will have the widest tire I can fit under it. Thanks for the help.
Old 06-04-2009, 03:06 PM   #4
turnleft
CF Member
turnleft's Avatar
You have to watch the rim/tire combination when going over a 5 inch backspace. Although you won't hit the trailing arm (with the relocated PB cable) depending on the rim diameter and tire sidewall you will find contact with the upper portion of the frame. Borrow some wider wheels if you can and measure. I have 16X13" rims with a 5 inch back space under ZL-1 flares on a 69.
Glen
turnleft is offline   Reply With Quote
Old 06-04-2009, 05:31 PM   #5
63_GrandSport
CF Senior Member
Quote:
Glen
So it may not be abad idea to do the wheel well flares aswell? If I did that how would the back spacing be then? I would not mind puting 325 on the back. Its going to get skinnys up front. so I want as wide as I can get in the back. Thanks
Old 06-05-2009, 07:28 PM   #6
turnleft
CF Member
turnleft's Avatar
Same thing applies on the backside,anything over 5" you need to mock up first.
Old 06-06-2009, 03:04 AM   #7
Bee Jay
CF Senior Member
Bee Jay's Avatar
I ran 9.5" wheels with 275/40-18 tires with stock trailing arms and modified sway bars and 2.5" adapters. I notched the frame and installed offset trailing arms to mount 10.5" wheels with 295/35-18 tires and 2" adapters. That's six inches of backspace. Check my signature for the mods or search in C3 under Bee Jay.
Bee Jay is offline   Reply With Quote
Reload this Page Back spacing for c3?
Tags
15, 1979, 295, 2955015, 50, back, backspacing, c3, corvette, spacing, stock, tires, vette, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
new wheels for c-3s vetteman1100 C3 Tech/Performance 12 07-27-2004 07:20 AM
Wheels on C3's if you know wheels then please answer wgc_3 C3 Tech/Performance 16 07-08-2004 01:38 AM
Tire Size, 305/50/15 too big for rear? mandm1200 C3 Tech/Performance 15 03-18-2004 09:43 AM
Z06 wheels on my C3... what do i need to make it work? '79ProwlerOrange C3 Tech/Performance 20 11-06-2003 03:19 AM
C3 Tire/wheel question... GrandSportC3 C3 Tech/Performance 37 05-18-2003 11:59 PM
The list of wheels for a C3............. Ryan77 C3 Tech/Performance 30 02-23-2003 11:04 PM
C3 wheel question Titanium Rat C3 Tech/Performance 9 01-07-2003 04:50 AM
HELP???? Which rims would you buy for my car???? 1Bad69 C3 Tech/Performance 31 11-14-2001 09:42 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
