Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-07-2002, 05:31 PM   #1
out2run
CF Senior Member
out2run's Avatar
Default 275/40/17 fronts and 285/40/17 rears affects on handling?
Any problems with the ASR running with the different size tires?
out2run is offline   Reply With Quote
Old 02-07-2002, 08:08 PM   #2
rbeckham
CF Senior Member
Default Re: 275/40/17 fronts and 285/40/17 rears affects on handling? (out2run)
None at all. My 1993 40th Anniversary Coupe with ZO7 suspension came with 275s front and rear on 9.5" wheels. I immediately changed to 285s in the back and never had a problem. But don't put the 275s on the smaller (base) front wheels. The 285s would benefit from wider rear wheels, but will work OK on the stock wheels.
Regards, Robert
rbeckham is offline   Reply With Quote
Old 02-09-2002, 02:53 AM   #3
Danger Dave
CF Senior Member
Danger Dave's Avatar
Send a message via AIM to Danger Dave
Default Re: 275/40/17 fronts and 285/40/17 rears affects on handling? (rbeckham)
Thats exactly what I run on my car. No problem at all. :yesnod:
Danger Dave is offline   Reply With Quote
Old 02-09-2002, 07:46 AM   #4
GUMPA
CF Senior Member
GUMPA's Avatar
No problem........ :nono:
But for Maximum performance and handling I found 285/315 combo, the Best.... :yesnod:
A ZR1 comes w/275 and 315...........285/315 is even better.... :reddevil
Wheels needed for 285/315 combo are 17 x9.5 x 56 front and 17 x11 x 50 rear :)
GUMPA is offline   Reply With Quote
Old 02-09-2002, 11:07 PM   #5
out2run
CF Senior Member
out2run's Avatar
Default Re: 275/40/17 fronts and 285/40/17 rears affects on handling? (GUMPA)
Thanks for input
Decided to run 285's Firestone sz50's on all four.
Old 02-10-2002, 02:13 AM   #6
GlockLT4
CF Senior Member
GlockLT4's Avatar
Send a message via AIM to GlockLT4
I like my 275/315 ZR1 combo (on zr1 offset wheels of course)
GlockLT4 is offline   Reply With Quote
Reload this Page 275/40/17 fronts and 285/40/17 rears affects on handling?
Tags
17, 2754017, 285, 2854017, 40, rims
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
