Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2002, 09:14 PM   #1
Curtis629
CF Senior Member
Curtis629's Avatar
Default Torque specs needed for adapters, and should I use thread lock?
I just got a set of '93 17" rims from another forum member. The fronts fit ok but the rears are rubbing a little on the brace that holds a rubber stop. I assume this is to keep the rear from bottoming out on the body. Anyway, I ordered a set of adapters from Mid-America. They are suppose to come in tomorrow. When I bolt these on, should I loctite the threads and if so with what kind? What torque spec? 30-60-90 in star or 30-60-100 ft/lbs in a star? The car is an 86, and the rear has been lowered 1.5" to level it out.
Thanks,
Curtis629 is offline   Reply With Quote
Old 02-06-2002, 12:19 PM   #2
Swamp Thang
CF Senior Member
Default Re: Torque specs needed for adapters, and should I use thread lock? (Curtis629)
Do not use Threadlock on your wheelstuds !!
Swamp Thang is offline   Reply With Quote
Reload this Page Torque specs needed for adapters, and should I use thread lock?
Tags
lock, spec, thread, torque
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
