Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2009, 04:14 PM   #1
Gohard777
CF Senior Member
Gohard777's Avatar
Default What tire do I get????
Trying different Forums, general, autocross, drag racing. I need help with tire selection. This is technical and performance related. I like to drive at high speeds when available, taking curves fast, but would like to hook up a LOT better than I do with the run craps. 17x9.5 front 18x10.5 back, want a 295/35/18 out back. Do Drag radials work in the curves, what about an autocross tire for everyday use? Don't care about wear, 8 - 10,000 miles on the tires are fine with me. I want to drag race once or twice a year, so would like a tire that can hook up. I know. I've already said that. So that's it, hi speed, curves, drag racing, what tire do I get? Please help.........bob.
Gohard777 is offline   Reply With Quote
Old 04-01-2009, 04:56 PM   #2
CarBoy
CF Senior Member
CarBoy's Avatar
Quote:
Based on what you've said, then the tire for you would be the Nitto NT555 R Extreme II
This is a drag radial tire/compound but with a stiffer side wall so you won't lose any cornering ability and has excellent strait line traction.
It is strongly recommended that you get the tires ordered heat cycled (at least for the rears) to give them a more even wear and longer tread life. and on a 10.5" wheel you can run the 305 in width and will fit just fine on the car and will look very tough.
Enjoy
CarBoy is offline   Reply With Quote
Old 04-02-2009, 06:32 PM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
there are a few goos choices but, much like shoes no 1 is a perfect fit that can do everything. I personally think the Pilot Sport PS2 is the most versatile option out there
Luke@tirerack is offline   Reply With Quote
Old 04-07-2009, 02:00 AM   #4
Gohard777
CF Senior Member
Gohard777's Avatar
Thanks guys.........bob.
Old 04-08-2009, 09:58 PM   #5
Tonycpa
CF Senior Member
Tonycpa's Avatar
1) Drag radials do not work well in curves. The reason is because a drag radial has a softer sidewall then a road racing tire enabling you to hook better from a dig. Since you only drag race once or twice a year it would be silly to get a drag radial. You would be much better off with a road racing tire for a daily driver.
2) If you like stability at high speeds, some wet traction, and excellent cornering ability then you can't go wrong with the sticky R compound Toyo R888 competition road racing tires. Especially if you have a high horsepower car. Since this tire is an R compound tire it will enable you to hook better than a regular performance tire like a Michelin Pilot Sport 2 which would be the best all around tire if tire wear was a greater concern and if you didn't have a higher horsepower car.
Based on what you are requesting...I recommend the Toyo R888s
Check out this vid...
http://www.youtube.com/watch?v=Rw2lbwPZ5x4
Quote:
Tonycpa is offline   Reply With Quote
Reload this Page What tire do I get????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do I get more traction. With my mods, I lose trac. in 1st beyond 4000 -> dizwiz24 C4 Tech/Performance 16 02-13-2003 04:07 PM
How do I get the little fan temperature sensor plug out of the L98 head? Siveck C4 Tech/Performance 9 02-09-2003 09:48 PM
How do I get GM Dealer Corvette service? Factory Correct Resto 13 11-09-2002 09:09 AM
Running 2000 rpm's @ 80 M.P.H. What gears do I have? champs_97 C4 Tech/Performance 17 08-29-2002 06:09 AM
Help me out guys. How do I get my car to go fast in a straight line??? vette.se Drag Racing 11 07-28-2002 08:33 PM
What rear do I have??79 Vette RPM's real high!!! BADCAIMAN C3 Tech/Performance 16 03-05-2002 01:50 PM
How do I get rid of this horrible wheel hop? rfgoss1 C5 Tech 17 11-12-2001 11:26 AM
Differential lube... how do I get the plug out? Shark Racer C3 Tech/Performance 14 08-28-2001 10:13 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
