Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2009, 11:23 AM   #1
ALVETTE00
CF Senior Member
ALVETTE00's Avatar
Default 275 series tire, how much HP?
Guys,
How much power can you put to the ground on the street with the 9.5in rim and a good 275 series tire/drag radial? I have T1-R's now.
I'm expecting ~420rwhp and would like to plan ahead if traction is going to be a problem.
al
ALVETTE00 is offline   Reply With Quote
Old 04-01-2009, 11:48 AM   #2
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
At that HP level, you will be able to smoke any tire be it a street tire or a R-compound tire. My 02 coupe with a Vortec blower has 443 RWHP and even with Active Handling on, my old Toyo T-1S tires would simply go up in smoke.
If you are looking for handling, then there are a number of good street tires that will work to make the car handle, but big HP numbers are not always a consideration for handling on the street.
And FWIW, I would not personally consider a drag radial for street use if you are going to be tossing the car around in the curves or doing autocross or track days. Drag radials typically have a softer sidewall and that could cause handling issues considering that the front tire would have a much stiffer sidewall.
You might want to look at the Kumho Ecsta XK or the Falken Azenis RT-615. Other examples might be the Nitto NT05 or BFG KD's (pricey but very sticky in the dry). Tires like these will not have great wet performance and use on ice or snow is not recommended at al by their manufacturers.
c4cruiser is offline   Reply With Quote
Old 04-01-2009, 02:54 PM   #3
ALVETTE00
CF Senior Member
ALVETTE00's Avatar
Thanks...
The T1-R's have a rating of 280 as compared to Nitto555's 300. Bit softer, we'll see how they hook?
I realize I probably wont be able to put the gas to the floor like a do now. I'm more concerned about potential for breaking loose at the shift points...that could be really dangerous.
Reload this Page 275 series tire, how much HP?
Tags
275, series, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Brake Rotor Diameter? teabagger C6 Z06 Discussion 13 05-25-2005 07:28 PM
2005 Z06 Offical Gm Press Release NOVAVETTE C6 Corvette General Discussion 20 01-07-2005 10:38 AM
GM release (from another forum) Runge_Kutta C6 Z06 Discussion 11 01-05-2005 11:08 PM
Radical Design....Not? Shylor C6 Corvette General Discussion 20 06-20-2003 12:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
