Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-29-2002, 02:55 PM   #1
dantos
CF Member
Default Optimum wheel width
What is the optimum rim width for 315/35/17 and 335/35/17 tires? The car is used basically for weekend road racing. Is there a rim width that would be acceptable for either of the mentioned tires?
Thanks,
Steve
dantos is offline   Reply With Quote
Old 01-29-2002, 03:28 PM   #2
SWCDuke
CF Senior Member
Default Re: Optimum wheel width (dantos)
Check the manufacturer's web sites for the specific tires you are talking about. Look at the specification page for the "design" width and acceptable range. The best width is usually something between the design width and the maximum.
If you mount a tire on a width narrower than the narrowest width in the acceptable range, tire performance can be compromised and with short sidewall tires, widths outside the acceptable range should be avoided. Buy a tire the is correct for your wheel width, or get the proper width wheel for the tire you want to run.
Duke
SWCDuke is offline   Reply With Quote
Old 01-29-2002, 07:06 PM   #3
gcrouse
CF Senior Member
gcrouse's Avatar
For many tires I've looked at (michelin, pirelli, yoko, bfg, dunlop, goodyear):
315: design rim width = 11.0", range 10.5-12.0"
335: design rim width = 12.0", range 11.0-13.0"
For road racing, I like to get rim width at least 90% of section width, for maximum tread flatness/support. This suggests 315s on 11.5" and 335 on 12.5". Like the man said, it's usually between the design width and maximum; definitely don't go smaller.
gcrouse is offline   Reply With Quote
Reload this Page Optimum wheel width
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
any one try 315 bfg drag on 10 1/2 zo6 roy thomas C5 Forced Induction/Nitrous 12 01-09-2004 03:47 PM
Does wheel width affect alignment ? Total Recall C4 Tech/Performance 12 12-21-2003 06:37 PM
Optimum wheel tire sizes for road raceing? NJ99FRC Autocrossing & Roadracing 13 11-02-2003 10:44 PM
Widest tires to fit on stock front rim???? chuckster C5 Tech 9 06-05-2003 10:06 AM
Quick Tire Question 95vett C4 General Discussion 10 03-11-2003 01:54 AM
Different camber settings between front and rear, why??? LTC Z06 Autocrossing & Roadracing 33 01-28-2003 02:44 AM
Aftermarket Rims and tires on 66', what will fit? bigblock66vette C1 & C2 Corvettes 15 01-19-2002 08:00 PM
Best Tire Sizes for Stock C5 Rims Kevman C5 Tech 12 09-17-2001 11:47 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
