Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-23-2009, 02:21 PM   #1
STROK3D
CF Senior Member
Default Other than looks (C5), why not keep 18" all around?
I can understand the reasoning because of the looks, but is there any other reason no one (or very few people) runs 18" wheels on all four corners on a C5? I'm looking at tire prices being a big deciding factor in this. 18" tire are much cheaper overall than going with 19's. I'd also like to keep the option of running a DR, and I don't think anyone makes them in 19". Someone help me out here.
STROK3D is offline   Reply With Quote
Old 03-23-2009, 08:41 PM   #2
Shirl
CF Senior Member
Shirl's Avatar
Just go with the 18's all around. They will be fine and look good too. Just be sure to stagger the wheel sizes properly.
Shirl is offline   Reply With Quote
Old 03-23-2009, 09:47 PM   #3
STROK3D
CF Senior Member
If I go with 18" all around it would probably be 18x11 and 18x9.5.
Old 03-23-2009, 11:31 PM   #4
Shirl
CF Senior Member
Shirl's Avatar
Quote:
That's good. Just make sure the wheel diameter is at least a half inch bigger in the rear, otherwise the traction control will come on.
Old 03-25-2009, 07:02 PM   #5
STROK3D
CF Senior Member
Quote:
So... 18's all around wouldn't work, then.....?
Old 03-26-2009, 07:55 AM   #6
leadfoot4
CF Senior Member
leadfoot4's Avatar
I think you mean the TIRE diameter.....
leadfoot4 is offline   Reply With Quote
Old 04-03-2009, 12:06 PM   #7
VerTigo456
CF Senior Member
St. Jude Donor '08
VerTigo456's Avatar
Quote:
18's around run just fine as long as it is a correct setup...and do look good too!
VerTigo456 is offline   Reply With Quote
Old 04-08-2009, 10:04 PM   #8
Tonycpa
CF Senior Member
Tonycpa's Avatar
I run 18s all around on my C5. Click my avatar and then select the option to go to my homepage here at CF. Scroll down to the mods section to see excat tire and wheel sizes
Tonycpa is offline   Reply With Quote
Old 04-10-2009, 11:47 PM   #9
Shirl
CF Senior Member
Shirl's Avatar
Oops, my bad. Thanks for the correction. I meant stagger the TIRE diameter.. The fronts should be at least a half inch less than the rears to keep the traction control from coming on.
Old 04-11-2009, 12:57 AM   #10
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
Support Corvetteforum!
1bdasvt's Avatar
I've got 18's all around!
rear:18x13 front:18x9.5
1bdasvt is offline   Reply With Quote
Old 04-20-2009, 02:10 AM   #11
spiral04
CF Senior Member
spiral04's Avatar
Quote:
What about running all 18" Z06 Speedlines and run the 305 R88's front and rear for HPDE's??
spiral04 is offline   Reply With Quote
Old 04-27-2009, 05:05 PM   #12
Rickyh93
CF Senior Member
Rickyh93's Avatar
That should be fine. I have a few buddies that ran that set up without issue. I have 315/30's all around on stock 18x10.5's with no issues yet.
Rickyh93 is offline   Reply With Quote
Reload this Page Other than looks, why not keep 18" all around?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
