Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-15-2009, 03:33 AM   #1
ScottJ03
CF Senior Member
ScottJ03's Avatar
Default C6 with Widebody what 20" rim size and tire..
are you using?
When you add fenders - does the width just go out.
I have HRE 20x10.5 and want to put 345/25/20.
Can I just get a new front lip half and be good.
or need both? Does it make it 2" wider +or- ?
Please advise.
Thanks,
Scott
ScottJ03 is offline   Reply With Quote
Old 03-16-2009, 04:01 AM   #2
ScottJ03
CF Senior Member
ScottJ03's Avatar
Default ttt
ttt
Old 03-18-2009, 01:31 AM   #3
geewez
CF Senior Member
geewez's Avatar
Default Widebody wheels
I installed the Z06 rear fenders only and ordered a set of iForged wheels in 19x9.5" front and 20x13" rears. I was recommended to run 265/30x19" front tires and 345/25x20" rear tires. Depending on the offsets of your current wheels, I believe that that you could have the wheel builder rebuild the rears with a wider outter rim half. 20x13" should be no problem. Stock Z06 rear wheels are 19x12" so increasing it an inch to 13" wide is no problem for the wider fenders. Best to contact your wheel manufacturer.
geewez is offline   Reply With Quote
Old 03-18-2009, 06:55 PM   #4
COR Wheels
CF Senior Member
COR Wheels's Avatar
Hey Scott,
If you have C6 brakes and do not plan on upgrading you should be able to add 1" outside and 1" inside depending on the fitment. Best bet would be to head over to a Wheel shop for them to measure the offset to be able to determine what you can do. You can run from 12" to 13" rear without any problems.
Hope this helps
Tony
COR Wheels is offline   Reply With Quote
Old 03-18-2009, 09:42 PM   #5
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
Support Corvetteforum!
1bdasvt's Avatar
You'll need at least a 12" rim for that size tire,,my rims are 13" with the 345/25/20's
1bdasvt is offline   Reply With Quote
Old 03-18-2009, 10:15 PM   #6
ScottJ03
CF Senior Member
ScottJ03's Avatar
Default My current wheels are
HRE 890
20 x 8.5 ET 67 Rims: Inner = 8.5" & Outer = 2"
They are made for Z06 Brakes currently.
My question is :
Is the width needed just on the outer?
Go to a 4" or 4.5" Outer?
Thank for the Info
Reload this Page C6 with Widebody what 20" rim size and tire..
Tags
1994, 20, 20s, 20wheels, c5, c6, corvette, rim, rims, size, sizes, stock, tiree, wheel, x13
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
