Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
View Poll Results: Down to what temperature do you use summer tires on clear sunny days?
40F or up 9 37.50%
32F to 39F 5 20.83%
20F to 31F 2 8.33%
Below 20F 6 25.00%
Use winter tire, don't drive it during winter, etc 2 8.33%
Voters: 24. You may not vote on this poll
Old 12-13-2008, 12:23 PM   #1
opua
CF Senior Member
opua's Avatar
Default Summer tires in cold dry sunny winter days
As I got into my car today after grocery shopping at Wegman's, I happened to glance at the MB CLS-55 AMG. I noticed that it wore summer tires. Temparature wise was 30F, with day time high projected to be 38F. Then my curiosity got into me. I looked around and saw a Boxster and a Corvette Z06. (This Wegman's is in a well-to-do area.) I checked their tires, and both wore summer tires. Which got me thinking ....
to those who live in the cold weather, how cold do you drive your car with summer tires on at the time you go out?
- Assume day time high will be 5F higher than when you're about to go out.
- Roads are clear, free of ice, snow, salt and it's a beautiful day.
opua is offline   Reply With Quote
Old 12-18-2008, 03:11 PM   #2
Joey D
CF Senior Member
I just dont mash the gas when its cold out and I'm fine. Thats really it...just a matter of self control, which is not alwways so easy.
Joey D is offline   Reply With Quote
Old 12-27-2008, 11:40 PM   #3
the blur
CF Senior Member
the blur's Avatar
It depends on the tire.
I had bridgestones and firestone summer tires, that were useless under 35 degrees.
I currently have Kumho summer tires, and they are fine all year long.
But for the most part, I switched to all season tires.
the blur is offline   Reply With Quote
Old 01-02-2009, 01:10 AM   #4
c4zf6nut
CF Member
Which Kumho do you have? My father has MX (KU15) and I told him to park the car if the temperature is 40 or below.
c4zf6nut is offline   Reply With Quote
Old 01-02-2009, 05:44 AM   #5
the blur
CF Senior Member
the blur's Avatar
The Kumho 712's seem ok in freezing weather.
any other "preformance" tire I owned was useless in the cold.
The Firestone's were the worst. The firestones went hard at 40 degree's.
Old 01-16-2009, 03:25 PM   #6
Oldvetter
CF Senior Member
Oldvetter's Avatar
It seems most tire companies consider 40 F to be the lower limit of summer tires, under that you loose more than 30% of your traction. But, if you don't have snow or ice, you are okay if you take it easy (and use traction control). Once snow or ice is present and under 40 F you are toast.
Surprisingly, even all-season tires (which say M&S (for mud and snow) on the sidewalls) aren't recommended for sub-freezing temperatures or deep snow. Only winter tires (they have a jagged mountain with a snowflake on it symbol on the sidewalls) are good in really low temperatures and snow. So you Canadian people are right in switching tires (but you knew that). BTW, if your tires don't have M&S or the jagged mountain on the sidewalls, they are summer tires.
Conversely, winter tires usually won't have a high speed rating, their soft rubber compound will wear too much and not hold up to high speed driving. They also have much less traction and poor handling in hot weather.
Oldvetter is offline   Reply With Quote
Old 01-26-2009, 03:45 PM   #7
troller399
CF Senior Member
Support Corvetteforum!
troller399's Avatar
"Roads are clear, free of ice, snow, salt and it's a beautiful day"
I just warm up the runflats before I get on it...
troller399 is offline   Reply With Quote
Old 02-03-2009, 02:30 PM   #8
zich6
CF Senior Member
St. Jude Donor '08-'09
zich6's Avatar
Temperture doesn't bother me, but I don't drive in snow, ice, or rain.
zich6 is offline   Reply With Quote
Old 02-08-2009, 06:41 PM   #9
cadguymark
CF Senior Member
cadguymark's Avatar
I live where it gets cold, real cold, where you have to consider the temp of the road surface, not the air temp. It can get to 50F air temp but the road surface still be near freezing here. I've had the GY Supercars slip when the air temp was 45F in the fall and above 50F in the spring. When you consider the engine is also making more power at those temps you gotta be careful getting on the gas. This is different than down south where the air temp can get below 40F but the road surface is well above that. Under those conditions, enjoy the extra power the engine is making.
cadguymark is offline   Reply With Quote
Old 03-24-2009, 09:40 PM   #10
SpiceyGTO
CF Senior Member
SpiceyGTO's Avatar
Location: Myrtle Beach & Greenville, SC -- Hung Like a Republican -- Network Admin/IT
I have been debating whether to get Summer tires again for my daily driver or if it would be safer to get an all season for the near freezing and freezing temperatures we (SC) get for about 3 months.
December through February are our colder months and we typically see temperatures in the 20s through 40s.
I am looking at the Direzza Sport Z1 Star Spec for a summer tire or the Bridgestone Potenza RE960AS Pole Position for a ultra high performance all season.
I have the Goodyear Eagle F1 GS-D3s now
Both tires get excellent reviews and the Bridgestone gets better treadwear and comfort ratings.
Is it worth it to get an all season for a few months of cold temperatures? I am not considering snow and ice in my decision, just cold temperatures and the effect it has on the traction of summer tires.
Here is Tire Rack's Survey Performance Chart for - Ultra High Performance All Season:
And Here is Tire Rack's Survey Performance Chart for - the top 10 Summer Tires of each cat.
__________________
PROUD OWNER (5-2006) of a 06 Spice Red A4 GTO
v3.826 V1
Pedders Serious Street Suspension + 70% bushings
DBA 4000 Rotors /w Hawk Ceramics
0 to 60 - 4.6 secs
-http://www.speedzones.com
-http://www.radarbusters.com
-Guys of Lidar - GOL
Valentine 1, Escort 9500ix - the 2 best.
Favorite cars: Vettes [C2,C3,C6], SS Camaros, M6 BMW, Aston DBS , and my sizzlin Spice Red GTO.
Coastal_Carolina over @ LS2GTO.com & Camaro5.com
SpiceyGTO is offline   Reply With Quote
Old 03-24-2009, 10:17 PM   #11
the blur
CF Senior Member
the blur's Avatar
all season tires ride nicer.
Reload this Page Summer tires in cold dry sunny winter days
Tags
california, cold, drive, freezing, limit, long, lower, nj, southern, summer, temperature, temperatures, tire, tires, warm, year
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Yikes! Minus 23 at my house this morning! StanNH C6 Corvette General Discussion 32 12-21-2004 11:36 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
