Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-29-2008, 02:06 PM   #1
JWOK94
Junior Member
Default Low Tire Pressure Warning System Changeout
I have a 1994 coupe with 30K miles and will be changing out the wheels to Gran Sport wheels (black 5-spokers) and will also be installing new tires.
What problems can I anticipate when moving the tire pressure sensors from the original sawblade wheels to the new Gran Sport wheels? Should I replace the sensors and the attaching band that goes around the wheel? I there any re-programming I have to do to the car's computer system?
I haven't made up my mind on what type of tires to go with yet, but they will NOT be the run-flat type that is currently on the car now(original factory tires). Any suggestions on tire type and manufacturer? I'm looking at Michelin, Perellis (sp?) or Kuhmos.
Thanks for any info. you folks could offer.
jwok94
JWOK94 is offline   Reply With Quote
Old 12-10-2008, 03:47 PM   #2
Dave S
CF Senior Member
Support Corvetteforum!
Dave S's Avatar
jwok94
The tire pressure sensors from the OEM wheels should fit the new wheels......"should" is the operative word....you'll have to check it out. If they do fit & if you're careful to label which corner the sensors came off of & be sure to mount then to the new wheels going to the same corner, you won't have any problems & won't have to do any re-programming. If, for whatever reason, you have to replace the sensors, you will have to have them programmed to the on-board control module. I know on C6's that process needs a Dealer tool....not sure about C5's....check your OM.
Dave S is online now   Reply With Quote
Old 12-11-2008, 12:11 AM   #3
the blur
CF Senior Member
the blur's Avatar
I have a spare band for sale, $25.
and a spare sensor $100.
specific to 94-96
the blur is offline   Reply With Quote
Reload this Page Low Tire Pressure Warning System Changeout
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
