Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-15-2008, 10:58 AM   #1
Ksths2
CF Senior Member
Ksths2's Avatar
Default Major Problem? - 2 bent C6 rims?
so i bought a used set of 05 C6 wheels and never thought a thing about it, well i dismounted the tires and stripped the clear coat off and working on repolishing the rims when i mounted a rim to check clearances and spun it and noticed a 1/4" drop on the inside bead.... the face and outside bead is perfect but the inside bead is bent to the center of the rim. So i installed all 4 and 1 rear does the same thing. I'd say this dude hit a pot hole and bent both wheels.
I honestly don't think the guy knew they were even bent because whoever mounted the last set of tires on them they had a ton of stick on wheel weights 180 degrees opposite of these bends and they ran those tires completely bald and the wear is even as can be. So i can't really be mad at the guy i bought them from i guess.
My question is, the rim is not oval or out of round, and you can't see any damage with the rim itself can i just install the new tires and have balanced and be good to go?
Or can i get these straightened some where???
Or what should i do?
I'm ready to mount these tires so i need help fast Thanks!
Ksths2 is offline   Reply With Quote
Old 08-15-2008, 02:57 PM   #2
waktasz
CF Senior Member
waktasz's Avatar
I don't know the answer to your first question, but there are lots of wheel repair places that should be able to help you.
This place for example
http://www.wheelcollision.com/
waktasz is offline   Reply With Quote
Old 08-15-2008, 02:59 PM   #3
Ksths2
CF Senior Member
Ksths2's Avatar
yep, i did a search and found them as well, i emailed them and we'll see what they say. Thanks
Old 08-18-2008, 09:58 AM   #4
Ksths2
CF Senior Member
Ksths2's Avatar
Update, the outter lip (face of wheel) is true, so i put a dial indicator on the inner bead and the worse rim has divit or dent of .080" so i got the ol' rubber hammer out and its working great, i've got it down to .043" - i ran out of time but i'll get it as close to .000" as i can. -
i got my tires in and just waiting on my sensors
Old 08-18-2008, 10:41 AM   #5
ccdan
CF Senior Member
ccdan's Avatar
Anything .025" or less would be more than acceptable.
ccdan is offline   Reply With Quote
Old 08-18-2008, 12:09 PM   #6
Ksths2
CF Senior Member
Ksths2's Avatar
yep thats my goal, i'm just look for a bigger hammer lol.
I can't believe i'm actually doing this fix with a rubber mallet but seems to be working and not hurting the rims so i guess i'll keep at it. Stay tuned
Reload this Page Major Problem? - 2 bent C6 rims?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
