Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-11-2008, 10:10 AM   #1
Ksths2
CF Senior Member
Ksths2's Avatar
Default TPMS keep or buy aftermarket
i sold my set of 4 02 C5 wheels/tires - i was planning on taking my TPS out of my wheels but the guy who bought them maybe interested in leaving the stock GM sensors and buying me all 4 new sensors to go into my C6 wheels.
My question is, Do you guys know where i can get replacement sensors that work with my OEM computer etc.
Thanks!
Ksths2 is offline   Reply With Quote
Old 08-11-2008, 11:34 AM   #2
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Thanks!
I'm not quite clear about what you're trying to do.
It sounds like you want to take sensors out of C5 wheels and put them in wheels that will go on a C6.
If that's what you're trying to do, it won't work. The C5 uses 2 different sensors (depending on model year), and the C6 uses an entirely different sensor than either C5 sensor.
If that's what you're talking about, you'll definitely need new sensors, because the C5 and C6 use different sensors.
There are essentially no after market sensors for any vehicles. Pretty much all the GM vehicles use sensors made by Schrader. You can get Schrader sensors through your local GM/Chevy dealership parts department, or you can get them from a Schrader distributor.
The GM Part# for C6 sensors is 25758220. If you can find them from a Schrader distributor you'll get Schrader Part# 20076 (or SB20076).
My recommendation is to get them from forum vendor Gene Culley. His website is:
http://gmpartshouse.com
Here's info from the website:
||--Tire Pressure Sensors--||
25758220 – Tire pressure sensor – 54.11 each
15234846 – Tire pressure sensor nut – 3.52 each
Total set of 4 nuts and 4 sensors 230.52
Also, I guess you know that in order to register the sensors on your C6 you'll need a tool that transmits a radio frequency to trigger the sensors - you can't use a magnet like you did with C5 sensors.
Bob
BEZ06 is offline   Reply With Quote
Old 08-11-2008, 11:37 AM   #3
Ksths2
CF Senior Member
Ksths2's Avatar
i've got a C5 and i bought a set of C6 wheels, these will be going on my C5 so i'll have to use C5 sensors...... right?
thanks for the help,
Old 08-11-2008, 11:46 AM   #4
BEZ06
Formerly beezeye
BEZ06's Avatar
Oh......and I guess you've got an '02 C5. In that case:
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 38.41 each
15234846 - nuts – 3.52 each
Total setup of 4 is 183.99 shipped!
Definitely let the other guy have the old sensors and get new ones for your new wheels. The internal batteries have a design life of 7 to 10 years, so you definitely should get new ones.
Bob
Old 08-11-2008, 12:18 PM   #5
Ksths2
CF Senior Member
Ksths2's Avatar
awesome! I think i'll take your advice and get new sensors, these are GM?? i mean not some knock off's?
Do i just need senosrs and nuts or do i need the washers, pressure sensor caps, and pressure sensor nuts also?
Basically, i'm needing all the parts to mount these in my wheels.
Old 08-11-2008, 12:28 PM   #6
BEZ06
Formerly beezeye
BEZ06's Avatar
There really are no knock offs. Schrader makes our sensors. The only ones sold by Gene Culley on his gmpartshouse website are official GM parts.
The sensors come with the grommets, a valve stem core, and a valve stem cap, but not the retaining nut. You'll have to order 2 part #'s: the sensors, and the nuts.
Bob
Old 08-11-2008, 02:25 PM   #7
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
The Tire Rack has the Schrader 315MHZ sensors
Luke@tirerack is offline   Reply With Quote
Old 08-11-2008, 02:41 PM   #8
Ksths2
CF Senior Member
Ksths2's Avatar
cool, thanks guys!
Reload this Page TPMS keep or buy aftermarket
Tags
25758220, aftermarket, c5, c6, gene, gm, grommet, part, tpms, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
