Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-06-2008, 12:10 PM   #1
Ksths2
CF Senior Member
Ksths2's Avatar
Default Is this a good deal for C6 wheels for my C5? Look inside for more details
i have a chance to buy a used set of C6 wheels with 2 Eagle F1's285/35/19 worn to the wear bars rear tires on the 19x12? rims & 2 Eagle F1's 245/40/18 100% worn out front tires on the 18x9? rims. 1 wheel has some curb scratches but not bent and i can sand/repolish these blemishes out. This deal is for $500 obo
Question #1 - is this a decent deal?
Question #2 - will these bolt on with no problems on my C5?
Question #3 - are the lugnuts the same between C6 & C5?
Question #4 - Will my TPMS work with these C6 wheels?
Thanks for you help!!!
Ksths2 is offline   Reply With Quote
Old 08-06-2008, 10:20 PM   #2
fat bob
CF Senior Member
Ksths2,
#1 If you check the C-6 parts for sale section, you should see nice polished wheels with no issues for $400-$600. I would not pay $500. for C-6 wheels unless they were very nice.
#2. I have tried this conversion on a friends C-5. The fronts will bolt on and fit and run perfectly. On most C-5's that I have read on the Forum,
the rears run a bit too close to the inside well as it pertains to tire clearance. My friends C-5 needed a spacer of approximately 1/4" for tire clearance. This is due to the increased positive offset of the C-6 rear wheel only. Front offset is fine.
#3. Lug nuts will work.
#4. C-5 sensors will not work in C-6 cars and vice versa but as you asked you can use your C-5 sensors in the C-6 wheels with no problems.
#5. You did not ask this but in case you want to know, the C-6 stock tires and wheels and C-5 stock tires and wheels are close enough that the very slight difference in OVERALL DIAMETER does not affect the computers as to AH, TC, ABS, or Speedometer Error. Your C-5 will not know or care that you have C-6 wheels as long as you use the stock C-6 tire sizes, your C-5 sensors, and probably a 1/4" spacer in the rear only.
Hope this helps you.
Bob
fat bob is offline   Reply With Quote
Old 08-07-2008, 12:45 AM   #3
Ksths2
CF Senior Member
Ksths2's Avatar
yep, this is exactly what i'm looking for... Thanks Bob!
i've got the chick down to $450 for the set, i'll keep looking though before i jump at the idea.
Any help on where to get the spacers???
Old 09-01-2008, 10:14 PM   #4
CPU64
Junior Member
Send a message via AIM to CPU64
Funny, I had to get a set of 2" adapters for my C5 wheels
CPU64 is offline   Reply With Quote
Reload this Page Will C6 wheels fit on my C5? Look inside for more details
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
C6 Vert Review with S2K Comparison: Warning---Epic length! S2K C6 Corvette General Discussion 47 02-27-2005 01:08 AM
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
The C6 is one big piece of .... bcmarly C6 Corvette General Discussion 39 09-06-2004 01:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
