Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2008, 05:27 PM   #1
atomik748
Junior Member
atomik748's Avatar
Default Wider Tires, AH&TC Issues?
I want to go up in sizes on the front and rear. I am wondering if anyone has had any issues with Active Handling/Traction Control when going with a wider tire? I want to go with 255/35-18 fronts and 305/30-19 rears. Heard lots of good things about Nitto Invos and my GYs are about done. I plan on changing the wheels too, 18x9 front and 19x11 rear. I have a 2006 Z51 Coupe and hope that this is all possible without any issues. With the right offset, they won't stick out or rub on the fenders, right?
I appreciate any help or advice I can get!!
Thanks,
Scott
atomik748 is offline   Reply With Quote
Old 04-27-2008, 10:51 AM   #2
trussme
CF Senior Member
trussme's Avatar
wider tires will not cause A/H or T/C problems, just rubbing issues that you can initially measure, calculate & prevent. Not maintaining the required height difference between front & rear WILL cause these DIC warnings to light up. Your tire selections mentioned above will work fine on the new wheel sizes you plan to install...and yes the Nitto "INVOs" are great!
trussme is offline   Reply With Quote
Reload this Page Wider Tires, AH&TC Issues?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
