Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-05-2008, 11:36 AM   #1
SPANKY LS1
CF Senior Member
St. Jude Donor '07
SPANKY LS1's Avatar
Send a message via AIM to SPANKY LS1
Default Powdercoating wheels, safe or not?
There have been some threads lately where the safety of powdercoated wheels has been discussed. Some feel that powdercoating wheels will weaken the wheel by altering the molecular structure of the wheel due to the heat required to cure the powdercoat.
I know that there are a BUNCH of powdercoated wheels on the forum, and I don't remember EVER reading of a wheel failure where the wheel did not hit a curb, a car accident, etc.
I know that, generally speaking, forged wheels are stronger than cast wheels. That being said, would a forged wheel hold up to the PC process better than a cast wheel?
Has anyone heard of, seen, read about, or actually experienced a powdercoated wheel failure or damage?
Curious as to your experiences, facts, opinions, etc.
Shawn
SPANKY LS1 is offline   Reply With Quote
Old 04-06-2008, 07:26 PM   #2
b_pappy
CF Senior Member
b_pappy's Avatar
Location: the GOCC are everywhere, even back from "band camp"
When the powder coating is cured correctly it should not affect the original temper of the alloy wheels. I recently had my Ronal centers powder coated, and am having another set of wheels done for my DD.
Bruce
b_pappy is offline   Reply With Quote
Old 04-07-2008, 01:55 PM   #3
zich6
CF Senior Member
St. Jude Donor '08-'09
Support Corvetteforum!
zich6's Avatar
Powdered coating typically involves temperatures below 500 degrees. Too low to effect any wheel metalurgy.
No problems with mine BTW.
zich6 is offline   Reply With Quote
Old 04-11-2008, 10:07 AM   #4
southern_son
CF Senior Member
southern_son's Avatar
There is a powder on the market that only requires temperatures under 250-300 degrees for curing. The only downside is the finish which is just a tad less smooth. Since there is a field of argument on the effect of transitional tempering of the metal even at low temperatures, I believe I would use the low temp stuff if it were me. However, when I painted my wheels, I simply used the hi temp caliper paint from a spray can and the finish looks pretty good. It is not smooth but I like the textured look of the wheel just fine.
Of course, you really need to be sure the applicator will use the low temp stuff because the temperature of their oven is probably set for other pieces while doing yours.
The above only matters if you decide there may be a problem, of course.....
__________________
Airport bum, Track bum, regular user of go-jo hand degreaser. LT4 - 372HP/355Torque, LS6 450HP/373 Torque.
southern_son is offline   Reply With Quote
Old 04-12-2008, 07:06 PM   #5
rfn026
CF Senior Member
rfn026's Avatar
I've been chasing this story for several years now. It's almost like an urban legend.
The only valid issue I've heard is that the wheels can crack from fatigue and you won't be able to be able to see the crack. Then again I've never seen a single case of this taking place, only heard the stories.
Now chrome plating - that's a big issue. That's for another thread though.
Richard Newton
Wheel and Tire Performance Handbook
Ultimate Garage Handbook
rfn026 is offline   Reply With Quote
Old 04-14-2008, 12:16 AM   #6
Rogue C6
CF Senior Member
Rogue C6's Avatar
I have had powder coated rims on 4x4s and Corvettes. I feel very safe having wheels powder coated. I have had no issues at all. I believe the temp is to low to do any change to the wheel. I can MAYBE see if a wheel already has a problem like a hairline crack, it could make it worse, but the chances of that seem very low.
I am currently having a set of C6 Z06 rims powder coated back.
The 4x4s I would take 4 wheeling in mud, sand, rocks, and water with no problems. AND they always looked good.
Playing:
Patrick
Rogue C6 is offline   Reply With Quote
Old 04-14-2008, 01:29 AM   #7
Mr. Peabody
CF Senior Member
Mr. Peabody's Avatar
Patrick
We're all so sensitive about taking our vettes out in bad weather ..... doesn't driving in the mud like that play havic with your wheel bearings and suspension seals, etc?
Mark
Say, has anyone ever powercoated just the blades of a set of sawblades?
__________________
Mr. Peabody
Mr. Peabody is offline   Reply With Quote
Old 04-16-2008, 02:54 PM   #8
Rogue C6
CF Senior Member
Rogue C6's Avatar
Quote:
Originally Posted by Mr. Peabody View Post
Patrick
Mark
Not on a 4x4 Vette.
That is why I have pickups too.
Old 04-16-2008, 04:47 PM   #9
Mr. Peabody
CF Senior Member
Let me try again
Patrick
We're all so sensitive about taking our vettes out in bad weather ..... doesn't driving your 4X4 TRUCK in the mud like that play havic with your wheel bearings and suspension seals, etc?
Mark
Old 04-16-2008, 06:45 PM   #10
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
I have personally seen wheels that were powder coated have severe structural integrity issues because of the heat used in powder coating ...
the process uses enough heat to cause annealling of the the metal. Wheels which are heat treated for added strength are affected more severely than wheels which are not heat treated.
Wheels that are destined to be powder coated are manufactured under slightly different conditions and processes.
I would not recommend power coating a wheel.
A large majority of wheels are painted
Luke@tirerack is online now   Reply With Quote
Old 04-17-2008, 07:27 AM   #11
hawkshil
CF Senior Member
hawkshil's Avatar
Send a message via Skype™ to hawkshil
Patrick
Mark
Thats what i wonto do with my vette is just powder coat the original saw blades
hawkshil is offline   Reply With Quote
Old 04-18-2008, 01:06 PM   #12
Rogue C6
CF Senior Member
Rogue C6's Avatar
Let me try again
Patrick
Mark
Sorry Mark
I always power wash my truck after play in the mud, snow, and sand. Trucks are designed to withstand added abuse, but I still like to get it cleaned as soon as possible. I have not had any ill effect yet. I take them to the Oregon Dunes also. The black F150, I had for 3 years, no problems. The new owner has had it for another three years and it is still on the road.
Patrick
Old 04-18-2008, 01:13 PM   #13
Rogue C6
CF Senior Member
Rogue C6's Avatar
Hi Luke,
Please do not take this personally, but I would like to see proof. I know you have more experience than I ever will.
I have had many wheels powdercoated and no problems. As seen, the wheels are also on 4x4s which exsert way more torque than an average car.
I have yet to see one verified case of wheel failure that has proven to be because it was powder coated.
If it is true, I would like to know also. I would stop having wheels powder coated.
Thanks,
Patrick
Old 04-18-2008, 01:30 PM   #14
Rogue C6
CF Senior Member
Rogue C6's Avatar
I found some reference material in this thread:
http://www.eng-tips.com/viewthread.c...151053&page=10
Quote I find interesting is:
"ASM Handbook Volume 2, Properties and Selection: Nonferrous Alloys and Special-Purpose Materials has the following information:
356-T6: aging at 305 to 315 °F for 2 to 5 hours
Yield stress = 185 MPa
Ultimate stress = 262 MPa
Fracture strain = 0.05
356-T7: aging at 435 to 445 °F for 7 to 9 hours
Yield stress = 165 MPa
Ultimate stress = 220 MPa
Fracture strain = 0.06
Based on these data, a 400 °F treatment for less than 1 hour shouldn't reduce the fatigue strength significantly. "
Patrick
Old 04-18-2008, 03:13 PM   #15
johninar
CF Senior Member
johninar's Avatar
I'm wondering if the cracked wheels that have been seen are from other causes, rather than the powder coating. Some GM wheels have less than stellar reputation.
johninar is offline   Reply With Quote
Old 04-19-2008, 10:16 AM   #16
southern_son
CF Senior Member
Quote:
Originally Posted by Rogue C6 View Post
Hi Luke,
Thanks,
Patrick
As with most phenomena in the field of physics, and as Einstein loved to say and attempt to prove, all things correlate. Perhaps you have heard of the new 'composite' type personal aircraft, plastic, if you will....
The reason they are mostly completely white is to lessen the deleterious effect of the sun shining on the aircraft while parked on the hot tarmac. The transitional temperatures weaken the structure. Of course I am speaking of those that are layed up 'cold' in the manufacture. One cannot see the effects, cannot feel the effects, and cannot really test for the effects nondestructively. But, push the extremes of the aircraft and it won't hold together after baking too hot.
As suggested in previous posts, you may consider just painting....
(I know I sorta stretched Einstein's simplified/universal theory above... )
__________________
Reload this Page Powdercoating wheels, safe or not?
Tags
bearings, c6, california, coating, forged, oregon, powder, powdercoating, rocks, safe, safety, southern, weakens, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
