Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-20-2007, 05:46 PM   #1
IRVINEC6
CF Senior Member
Default Taking out sensors
I have some new HRE's being shipped to me, and I was told to have the sensors taken out and sent to the shop shipping me the new wheels, so that I do not have to buy new ones. I just called America's Tire in my area, and they want $265 to take out the sensors.
What have you guys done in this situation? Is it better to purchase new sensors? How much are the sensors?
Thanks,
James
IRVINEC6 is offline   Reply With Quote
Old 12-20-2007, 07:26 PM   #2
openhelix
CF Senior Member
openhelix's Avatar
Just have the sensors swapped when you get the new tires mounted. Otherwise it's cheaper to just buy a second set of sensors.
openhelix is offline   Reply With Quote
Old 12-20-2007, 07:47 PM   #3
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
I got a set of chrome OE wheels about a year ago. To break down the tires off the old wheels, mount the sensors and tires to my new wheels, and balance all the wheels cost me 100 bucks at my local Discount Tire.
To get your sensors out of the old wheels they need to break down one bead and I think they can reach in and pull out the old sensors. That shouldn't cost much at all, unless you want them to mount some new valve stems in there with no sensors, and then rebalance the wheels - it still shouldn't cost more than 100 bucks!
If you're going to keep the old set of wheels/tires for HPDE's or auto-xing or something I think you should just leave the sensors in them. Even if you're going to sell them they might be easier to sell all mounted and balanced with the sensors in them.
If you want new sensors, they will cost around $200 or $220 from forum vendors. Check with Bob ( http://www.houseofwheelsonline.com/ ) or Gene Culley ( http://gmpartshouse.com ).
Our sensors are made by Schrader and Bob has them direct from Schrader which avoids the GM tax. Gene's are GM parts and cost a little more.
Or, I've got a set of used ones for $160 shipped. Problem is I won't be home until after Jan 1st.
Bob
BEZ06 is offline   Reply With Quote
Old 12-22-2007, 06:09 PM   #4
bizaro
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
bizaro's Avatar
Send a message via MSN to bizaro Send a message via Yahoo to bizaro
I left mine in my old wheels, when I sell the car they will go back on.
bizaro is offline   Reply With Quote
Old 12-23-2007, 02:17 AM   #5
IRVINEC6
CF Senior Member
Well, today I drove to lower income city and had them removed and rubber stems put in for $80.00 by a mom and pop shop. It seems like the tires chains do not like to do any work on your car unless you buy tires from them. I think that is why America's Tire quoted my the $260 price.
Old 12-31-2007, 03:05 PM   #6
GotVett?
CF Senior Member
GotVett?'s Avatar
Bob
Thanks for the advice, as well.
GotVett? is offline   Reply With Quote
Reload this Page Taking out sensors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Run Flats, Non- Runflats, Tire Options. Paras C5 Tech 27 06-13-2005 09:29 PM
What would cause my timing to cut out early? los7883 C5 Tech 19 11-01-2002 01:47 PM
Tire pressure sensors not showing correct pressure. Why? QuickSilver2002 C5 Tech 15 03-24-2002 11:26 AM
Where to get O2 sensors and oil level sensor... GlockLT4 C4 Tech/Performance 19 12-19-2001 11:42 PM
Goodridge SS Brake Lines + Wheel Pressure Sensors = ???? BAD2BNE C5 Tech 13 08-10-2001 04:03 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
