Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-10-2007, 05:11 PM   #1
Kale
CF Senior Member
Kale's Avatar
Default Losing air... slowly.
Right rear is losing air. VERY SLOWLY. I brought it up to 33lbs to test this.
So left was 30lbs right 33lbs. It slowly dropped over about a week, and now its 29lbs to the left tires 30lbs.
Also, maybe related, this wheel has about 15 or 16 1/4 ounce stickon weights needed to balance it. Bad wheel? Any good way to test it? Can I submerge it without worrying about tps? I assume the TPS is protected from submersion.
Kale is offline   Reply With Quote
Old 12-10-2007, 07:05 PM   #2
Mr. Azrael
CF Senior Member
Mr. Azrael's Avatar
Funny thing is my left rear is doing the same thing with the stock GY F1SC. I can not find anything that have punctured the tire and it loses only ~1psi per night... I have wondered if the wheel is bent but I can not see any signs of that either.
I am interested in the outcome, maybe I should just take it to a tire shop myself.
Good luck!
Mr. Azrael is offline   Reply With Quote
Old 12-10-2007, 09:20 PM   #3
Kale
CF Senior Member
Kale's Avatar
found a nail. Like, a finish nail. VERY small. Its in the side of a treadblock.
They won't fix it. Is it safe to fix?? Can I just ignore it, stick some silicone glue on it maybe??
Old 12-11-2007, 01:19 PM   #4
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
not repairable ..... live with it or replace the tire ....
Luke@tirerack is offline   Reply With Quote
Old 12-11-2007, 06:56 PM   #5
Kale
CF Senior Member
Kale's Avatar
Quote:
The expert has spoken.
Thanks.
Old 12-12-2007, 11:00 AM   #6
Luke@tirerack
St. Jude Donor '11
isn;t there some handy dandy KaleCo.com product to correct that problem
Old 12-12-2007, 11:49 AM   #7
Kale
CF Senior Member
Kale's Avatar
That's what caused the problem in the first place! Improperly installed lowering kit.
Old 12-16-2007, 03:09 PM   #8
XXXLTRP
CF Senior Member
XXXLTRP's Avatar
Good luck!
My left rear does the exact same thing. I have looked the tire over and over, I can't find anything in it. I replaced the valve core and still leaks. I covered it in soapy water...still nothing. I don't know if the leak is so slow that these tricks will find it. I'm putting my money on the valve seal. It's on it's second set of tires and I'm sure it's the first set of valve stems.
XXXLTRP is offline   Reply With Quote
Old 12-17-2007, 07:45 AM   #9
4GTABODT
CF Senior Member
St Jude Donor '07-'08-'09
Support Corvetteforum!
4GTABODT's Avatar
Location: Oakville, Ontario Corvettes were built to be driven...not trailered
Send a message via ICQ to 4GTABODT Send a message via AIM to 4GTABODT
Cancelled my reply as I misread the original post...apologies
Last edited by 4GTABODT; 12-17-2007 at 11:00 PM. Reason: Keyboard went into gear before brain did LOL
4GTABODT is offline   Reply With Quote
Old 12-17-2007, 10:11 PM   #10
Kale
CF Senior Member
Kale's Avatar
i tugged the stem, then turned it slightly. No more slight leak.
so I got brave and pulled the object.... no leak.
phew!
Reload this Page Losing air... slowly.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A/C woes round II. I’m losing the battle. Need your help to win the War DickieC.99 C5 General 15 07-02-2005 07:55 PM
tire losing air but cant find any leaks- dumbfounded TriPinTaZ C5 Tech 22 06-30-2005 08:26 PM
Free C1 disc brake conversion Plastic Pig C1 & C2 Corvettes 32 05-26-2005 10:42 PM
LT1 miss problem Toy90 C4 Tech/Performance 32 05-23-2005 12:19 PM
Shopping Tip: Run-Flat or Not? Mighty-Mouse C6 Tech/Performance 11 04-13-2005 03:32 PM
Vettes in the snow...CQ issue jricca C6 Corvette General Discussion 26 07-28-2004 07:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
